My Ocianic Blue Ur restoration
    replied
    At last we have some progress to report.
    replied
  • steve briance
    replied
    Can't get much simpler than that!
    replied
  • steve briance
    replied
    Nice one. They look made rather than purchased and that's the way it should be in my book.
    I don't have subframe holes on this car but thinking about it, the weight of the car sits on the wishbones so their mountings must be up to it for use with a trolley.
    Plastic or rubber wheels on your set up?
    replied
    Originally posted by steve briance
    What did you bolt your chassis moving trolleys to?
    For the first time in my motoring life to date, I'm about to get some indoor space to keep a classic car. Inevitably I'm already buying tools and thinking about things I might need for restoration purposes even though the car is currently still outside!
    One of the things I would like to do is remove engine and everything from the bay and push it outside for cleaning of engine bay, wheel arches, rust repairs, paint etc. I fancy a visit by a mobile grit blaster (it's that vs hours of angle grinder and wire brush) to do the cleaning and for that not to ruin things, I don't want any suspension, driveshafts etc to be on the car.
    I was thinking of making a trolley like yours and bolting to where the wish ones did before being removed...
    The trolley was made by a friend and was originally for the S2. The uprights have angle brackets that bolt into the subframe captive nut holes. I adapted it slightly to fit the Ur. The front mountings were identical to the S2, just the rear ones needed some angle iron adding and new holes drilling.
  • steve briance
    replied
    replied
    The welding is almost finished.
    replied
    Originally posted by tango123
    oh my That must have took some work getting it on the truck
    Just rolled straight on no problem. The dolly has wheels.
  • tango123
    replied
    replied
    Off she goes for serious welding (no G)!
    I was going to do it myself but I have to admit that some of it is beyond my skill level.
    replied
    [QUOTE=oldbiscuit;n2082958]
    Originally posted by Tractor Dave
    The diff gets a good scrub.
    The front ball joints got new rubbers.
    [IMG]https://uploads.tapatalk-cdn.com/20200203/9a6875970970ed4f1865dc13935905de.jpg[/IMG
    Hi Dave, I'm working on my 90 Quattro, had 2 new 19mm front ball Joint by wrong order, money been refunded, you can take it for free.
    That is very kind of you. I have sent you a PM
  • oldbiscuit
    replied
    [QUOTE=Tractor Dave;n2077287]The diff gets a good scrub.
    replied
    Thanks John. I will check those
    replied
    Windscreen removal did not go to plan.
    Someone had used panel bond inside the seal. It was never going to end well.
    I nearly said a bad word then
    Make sure the two drain holes under the seal in the bottom corners are open through to the scuttle.
