jbrentd's 2nd Chance CQ
  • jbrentd
    • Dec 2009
    • 247
    Hey all, I thought I would start a thread over here on for my CQ. I've been a member on here for a while, but never started a build thread of my own. I live in the US, more specifically, Northeast Oklahoma.
    I originally bought the car back in Feb 2010 from the Milwaukee area. Owned it for 4 years and did a decent amount of maintenance and rehab work to it.
    Day I brought it home
    Came with a crunched up spot on the driver's side (that was fun).
    Here are some highlights from the first time I owned it...
    • Timing belt job
    • Spec Stg 3 clutch
    • Euro front/rear bumpers and 1-piece headlights (relayed)
    • All new audio components
    • Replace heater core and rebuilt the airbox
    • Pearl white respray & some body repair
    Not long after I had it repainted, I bought an A6 and the coupe didn't get much road time. I didn't want to see it sit in the driveway getting unused, so I I sold it in Feb 2014. It was looking like this.
    After selling it, I quickly started to regret that decision. Since then, my oldest is off to college and my youngest is driving and I am finding more free time to work on a project again. So, in mid 2018 I contacted the guy I sold it to and found that it has been sitting in his garage for a couple of years. He was driving it for a while, but put it away when it developed a low end knock. He has a couple other projects going and was willing to let it go. So, I bought it back. While he owned it, he did a few things like finishing the DIY coilovers that I had all of the parts for, getting the A/C system working again, and some odd and ends.
    As it turns out, the "low end knock" was a bent rod and a bunch of bent valves from it jumping some teeth on the timing belt. I suspect a bunch of mud dauber nest debris as the reason for it being out of time.
    In my search for a replacement engine, I was offered a free, low mileage 7A. Was hoping to find a 20vt, but thought the 7A was the quickest way to get it up and running again. So, I started down the path of swapping in the replacement 7A.
    Took this opportunity to swap a Dave Kase recharged bomb.
    Just in time to celebrate getting the coupe back on the road, I found my long-term swap solution...lol. A friend and I bought a '91 200. I wanted all of the parts for the 3B swap and he needed more body and interior stuff for his project, so it worked out for us both. Wish I had found it first, but that's how it goes sometimes. I learned a lot with my first swap.
    I managed to get some Euro bits. 3B S2 intercooler and crossmember and an RS2 fan shroud to go with the 3B high powered fan. I need to figure out the wiring side of this.
    After a few months of just enjoying her, I recently started to work on the 3B.
    How she sits currently...
    Sorry for the long post. I look forward to spending more time on the forum.
    Brent
    2001 A4 Avant QMS - FXK04'd
    1991 Audi CQ - Project
    1996 A4 12v Quattro Manual - SOLD
    • 4754
    Great looking car and nice thread, looking forward to updates.
      • Dec 2017
      • 5987
      Welcome and don't apologise. Enjoyed it all
      • John.
        • 2615
        Nice !
        • jbrentd
          • Dec 2009
          • 247
          Thanks for the kind welcome.
          I dropped off the head with a local reputable machine shop, today, to get it cleaned up, decked and new valve seals. Hopefully, it’ll be crack free and good to go for a long time. It’ll get 7A cams upon re-assembly.
          I’ve read about different valve angles that can improve performance, but I have no idea what I would tell the guy, other than the factory specs. Any advice?
          I am starting to collect parts...in mass. Upper and lower gasket/seal sets, new brake pads/rotors, caliper rebuild kits, ball joints, engine/tranny/diff mounts, etc, etc. I already have all the AKMS poly bushings waiting on the workbench.
          Also looking at what is needed for relocating the batter to the rear. And I need to find a 3B S2 oil filter housing so I can keep the AC compressor in the stock 7A location. If anyone has a lead on one of those, please let me know. I see several on eBay.de, but not sure what the going rate for them are.
          My wallet is hurting. [emoji23]
            Great write up, interested to know some more about the bomb refurb if you have them?
            If you want to you can get the 7A head machined to accept the pickup for the hall sender on the cam and other elements so its easier to fit direct ignition coils too.
            • TimE-J
              • Jul 2009
              • 1292
              Looks like a great project, good luck with it
              96 S2 aby Coupe. Rebuild Project
              96 mk3 golf tdi daily.
              • jbrentd
                • Dec 2009
                • 247
                I guess it’s not really a refurb, more of a recharge along with adding a valve. My brakes were really improved after I had that done...working like they should.
                You can see the valve in that picture I posted.
                As for the head modification, I have thought about that, but I think I’ll be sticking with the distributor, at least for a while. My power goals are pretty modest. Plus, the harness I have is from a 3B.
                Brent
                • Lago Blue
                  • Jul 2009
                  • 843
                  Some of us live for those decent longer posts (with a good cuppa, as the hosts here might say); and second chances. Welcome.
                    Thanks Brent. I'll check them out. My brakes are loads better since I replaced a pinched seal in the caliper but Ive been chasing down an issue with the PAS reservoir draining and refilling on startup
                    • jbrentd
                      • Dec 2009
                      • 247
                      Cuppa joe? Or something stronger? Thanks
                      • jbrentd
                        • Dec 2009
                        • 247
                        I plan to rebuild my calipers too when she goes on stands for the swap.
                        • jbrentd
                          • Dec 2009
                          • 247
                          So, I have some questions about silicone hoses for coolant and intake piping. For some background, I have an S2 3B IC and crossmember and I plan to use the stock afterrun pump. Need to do some mock ups, but thought I would ask anyway.
                          Is it possible to get everything to work with a combination of 200 and CQ parts? If not, which ones don't work?
                          Or should I just bite the bullet and get all new silicone parts from DO88? (S2 3B pressure hoses, coolant hoses and turbo inlet hose) How's the quality of their stuff?
                            I can’t speak for DO88 but the roosemotorsport ones are used by lots on the forum
                            • jbrentd
                              • Dec 2009
                              • 247
                              Thanks for the info!
