My Coupe project
    • Dec 2017
    • 5987
    Get your hand underneath the clip and squeeze them together as hard as you can whilst pulling the bracket up. Release one side at a time. To get the cable off, pull the end away from the slot with long nose pliers and whilst holding it back, use your other hand to push a long flat bladed screwdriver under the little grommet and prise it out.
      • Dec 2017
      • 5987
      These are the four clips that you need to squeeze together.
        • Dec 2017
        • 5987
        The grommet fits inside this recess and is only held in place by the pressure from the spring on the end of the cable.
          • Dec 2017
          • 5987
          I picked up an undertray from another forum member a while back. It was a good fit. The car didn’t come with one.
          My bee sting was in a sorry state.
          Someone had used sealant and the rubber washer was missing.
          Cleaned up
          I happened to have a good bee sting and seal (as you do).
          And it fitted nicely.
          That’s not a scratch. It a reflection of a wire.
          Just had a call that my headliner and door cards are ready.
          • steve briance
            • Aug 2014
            • 1455
            Make sure the aerial is done up properly...
            When refitting mine all looked well until I went out in the rain and noticed in my rear view mirror drips coming out of the light fitting
            I seem to recall an o ring somewhere that might be worth checking is still soft.. Its been a while though so its possible ive made that up.
              • Dec 2017
              • 5987
              It's done up nice and tight and to be sure I did put a little ring of sealant around the base underneath.
              • Mikes2
                • 1704
                you can run a watering can over it to check for sealing. Saves finding out the hard way in the first downpour which I'm sure you get a lot of in Wales.
                Mike
                http://www.s2-audi.co.uk
                  • Dec 2017
                  • 5987
                  Nice sunny day here so made a start on re fitting the headliner and door cards.
                  I was on my own and this is really a two person job but it looks like I got it in straight.
                  I’m using this stuff which seems good.
                  Getting the seat belt trim back on correctly is quite difficult. It has to be lined up with the height adjuster.
                  I fitted new door card seals.
                  And changed the seat belt bolts as they were corroded.
                  Drivers door card fitted.
                  I ran out of time tonight. I will finish tomorrow. Just the nearside door card and boot carpet left to fit.
                  • B5NUT
                    • Sep 2021
                    • 1071
                    Do you have the part number of the plastic door card seals. One on my car is missing and cannot find it on etka.
                    • Beppo
                      • 28
                      Thanks. I´ll have another go at it. I can reach the first pair och clips but on the other pair the carpet i stiff and buldging so it´s har to get in there. I´ll just have to try harder.
                      Owner of S2 Irry-edition
                        • Dec 2017
                        • 5987
                        Oh dear
                        I got a bit carried away.
                          • Dec 2017
                          • 5987
                          Seal set for the doors
                          • B5NUT
                            • Sep 2021
                            • 1071
                            Oh dear
                            I've got an inch thick pile of receipts... I'm not going to add mine up as I'll just start to cry
                              • Dec 2017
                              • 5987
                              I know just how you feel. I have spent much much more on the Avant. I dare not add it up.
                              I hope my wife doesn't see this thread
                              • B5NUT
                                • Sep 2021
                                • 1071
                                It would be a cold day in hell before my wife looked at a car forum
