Originally posted by Tractor Dave
View Post
My Coupe project
I found small wire cutters worked. Snip the edge of the ring and they pop off. Now I need some new ones.
And I finally found something that melts the yellow goo.
Sent from my iPhone using TapatalkNothelle S2 Avant
Originally posted by Tractor Dave View PostI found small wire cutters worked. Snip the edge of the ring and they pop off. Now I need some new ones.
Originally posted by Nuvo View PostI've used a couple of flat blade jewellers screw drivers to fold a few of the teeth back a little to release the tension.
Just read your most recent post, don't think I have that many spare.
Good tip on the nail polish remover.Last edited by K Simmonds; 25 March 2022, 23:22.1989 B3 2.0 3A 80 quattro... Budget 1.8T Project.
Originally posted by LHD_Kid View PostThe yellow goo is water soluble (certainly that used on the headliner)
It never occurred to me to try using water as solvent for it, cheers for the info Chris, that's very good to know.1989 B3 2.0 3A 80 quattro... Budget 1.8T Project.
It's horrid to have to deal with I hate the stuff, maybe the yellow foam is different to the orange foam of doom.... I do know that you mustn't get it on Alcantara, I'm taking all the seat's out my car before I tackle mine.1989 B3 2.0 3A 80 quattro... Budget 1.8T Project.
Thanks Steve. Handy to know.
My slave arrived. These are original oe Sachs/BOGE unit with the Audi rings ground off. Buycarspares2 are selling them on eBay for £52 delivered. Bit if a bargain me thinks.
Now, there is a guide here for doing the slave so I’m not going to bore you with the process. However, the difficult part is getting the new slave in as you are working against a strong spring which you have to push in at the same time as locating the retaining bolt. I have discovered a little trick that makes this job a doddle.
Put some brake fluid in the new slave. Now make up a sealed fitting to go in the hose aperture. Compress the spring fully and hold it. Do up the fitting and the vacuum holds the rod in the slave. Now really easy to fit.
Bleeding can be a pain with these but this pressure bleeder seems to do the job first time with no issues. Happy days. Job done in just over an hour.
Old original Audi slave next to the new one.
- 2 likes
Today was a good day.
I fixed my lights.
I removed the plug behind the steering wheel and tested the wires using an external battery and a meter. Everything was good until I got to the lights. Both dipped beam bulbs had blown. Interesting.
Rust in boot has now had two coats of epoxy and some green to make it look half decent.
Now this afternoon I’ve got this to sort out. I think it’s the central locking box?
Anyone see one before?
And mow the lawn
- 1 like
As above, that's not factory, almost certainly aftermarket immobiliser and/or alarm sabotage.
I like your idea for keeping the piston retained under vacuum on the slave, I'm going to make a bung and add to my my home made tools draw.
It could just be the epoxy paint, however it looks the bottom nearside rear corner of the car has a light tap, is there any sign of damage on the outside?1989 B3 2.0 3A 80 quattro... Budget 1.8T Project.
