My silver RS2 Project
    • Dec 2017
    • 5990
    My clutch arrived. Looks good.
    And I found a piston. Hurray.
    • Shenkm87
      • Sep 2012
      • 32
      Some amazing progress!! Good luck!
        • Dec 2017
        • 5990
        Piston arrived. It's in excellent shape.
        So I wasted no time. Ring gaps were checked.
        All were in spec and I didn't need to file any.
        Then I got cracking.
        Everything went smoothly despite using cheap ring pliers and ring compressor.
        I've used assembly lube in all the bearings.
          • Dec 2017
          • 5990
          The pick up got a really good clean. There were a few lumps of hard black plastic in there.
          And the sump got a final clean.
          I'm using a belt and braces approach to sealing. This stuff is a good way to provide some extra sealing.
          This little o ring isn't in the full gasket set. I happened to have a new one in my parts stash.
          And we got busy.
          Small allens 10nm and the three larger bolts 20nm. Tighten in stages and in a diagonal pattern.
          The oil pick up bolts are 10nm. The longer ones have lock washers. I used a little thread lock on the other two.
          • ottawa coupe
            • 854
            Hylomar is magic. I love it and use it on all surfaces now, gasket or no gasket. I had a 16vt race engine that i could not stop leaking at the valve cover. To the point of oil fire(s!!!!) At the turbo. Used this stuff, dry as a bone from then on.
            1993 UrS4...aka the rocket powered living room
              • Dec 2017
              • 5990
              I've done very little due to still not being 100%.
              It's been very mild and damp so I wanted to get the engine block sorted before it starts rusting in front of me.
              The oil pump housing and pressure senders got fitted. All the other holes into the block got sealed up before I started cleaning. The block then got a good wire brush and treated ready for paint.
                • Dec 2017
                • 5990
                The block got some good quality engine enamel. I fired up my little heater to help warm things up first.
                Then today I made a start fitting the head.
                New gasket.
                Some cut off old head bolts make a handy guide.
                The head is nice and clean. New exhaust valve guides have been fitted and it's had new valve stem seals and a light skim.
                On it goes.
                New head bolts got a light coat of light oil.
                Then torqued up in sequence.
                Hydraulic tappet buckets were cleaned and oiled before going back in the same holes they came from.
                Next job is the camshafts.
                  • Dec 2017
                  • 5990
                  Everything cleaned and lubed up nicely.
                  New chain.
                  And new seal.
                  Fiddly but got them lined up nicely.
                  • 4WDrifter
                    • Nov 2012
                    • 1251
                    #129
                    Great progress Dave. It took me about 60 seconds to read about and view the pictures of a good few hours work there. Thanks again for taking the time to provide us with the photographic record.
                    1996 S2 ABY Coupe silver
                    2003 S3 8L dolphin grey
                    2014 RS4 B8 prism silver
                      • Dec 2017
                      • 5990
                      You are welcome. After seeing the pics myself I went straight back out to the garage. The fourth pic makes it look like the cam timing is wrong, but its just the camera angle and taken before caps fitted. Gave myself a shock!
                      • Blagave
                        • Aug 2023
                        • 270
                        Dave, you are a machine, just love your build threads.
                          • Dec 2017
                          • 5990
                          Thanks. Enjoy yours too.
                          I gave the rocker cover a wash.
                          And fitted the cam position sensor and top pulley. Plenty of thread lock here and 65nm whilst pulley supported.
                          • K Simmonds
                            • Dec 2007
                            • 7627
                            Great work there Dave, you've done a smashing job of that engine inside and out.
                            1990 B3 2.0 80 quattro.
                            1992 C4 2.8 Avant quattro
                            1994 MTM RS2.
                            1998 B5 TDI quattro Sport.
                            2000 B5 TQS.
                            • 5cylinderman
                              • Oct 2011
                              • 367
                              Wow, is that the latest EFR turbo on the right???
                                • Dec 2017
                                • 5990
                                Its the Welsh developed "Gwynt Poeth" special
