My silver RS2 Project
    • Dec 2017
    • 5992
    https://www.ebay.co.uk/itm/306042966...Bk9SR_z1qa2YZQ
    • John.
      • 2615
      Originally posted by Tractor Dave
      I couldn't find the originals. The auto doc ones I ordered a couple of years back didn't fit at all. I have found bump stops from an alfa gtv that fit not too bad. I have a spare set here I think.
      Alternatively, Classic Quattro (Simon) sells a set of bumps and boots that fit ok ish.
      Cheers, I'll hunt around. CQ's could be a last resort .
        • Dec 2017
        • 5992
        Send me your address and you can have my spare pair of bump stops
        • John.
          • 2615
          Dave, thank you, that's a very kind offer but at the rate you acquire projects you'll need them before I get around to getting the struts off my car !
          Seriously though, I'm not in a hurry so have time to look into it.
          Many thanks.
            • Dec 2017
            • 5992
            Send me a pm mate and i will explain
              • Dec 2017
              • 5992
              So yesterday morning there was another small patch of oil under the car. I was busy doing other things so put off the inevitable strip down until today. When I went out to the car this morning I had a good look at the oil. Its green! So on further inspection I found this connection to be the culprit.
              I wasn't tight! I remember now putting off the final tightening until the pump was in place. Doh. Obviously forgot. Anyway, stripped the front down to double check the oil pump and front crank seal. All looks good.
              Now I just have to put it all back together again.
                • Dec 2017
                • 5992
                All back together again and nice and dry underneath. Phew
                • jubjub
                  • Nov 2003
                  • 1239
                  A hell of a lot of work. All your projects are. You could have made a career out of restoration. You put a lot of so called pro's to shame. Top work
                    • Dec 2017
                    • 5992
                    Thank you. I do my best.
                    Now, back to those front drive shafts.
                    I re built the cv's making sure all the marks I made line up and everything is super clean.
                    Annoyingly, the SKF inner joints don't come with new cork seals. Luckily I happened to have a couple of new spares.
                    The ends of the shafts are wrapped in insulation tape to help get the very tight boots on.
                    The joint is tapped on using a rubber mallet.
                    New circlip.
                    Then onto the outer joint.
                    And we are soon done.
                    A quick tea break
                    Then onto rebuilding the other.
                    Fitting time.
                    Flanges cleaned up.
                    The tab washers cleaned up nicely and didn't need paint.
                    And installed
                    The SKF boot kit comes with these lovely new 12.9 grade bolts. Unfortunately, they aren't very rust resistant. As soon as they were installed I sprayed everything with Bilt clear rust proof.
                    Fortunately I just had a new delivery of goodies from Bilt today.
                      • Dec 2017
                      • 5992
                      The ball joints are good but need a clean, paint and new boots.
                      Before and after
                        • Dec 2017
                        • 5992
                        Before and after a clean
                        Then some rust converter and masking.
                        And some zinc. They look nice silver. Maybe I will keep them like this?
                        I also cleaned and fitted the splash guards for the tie rods. I normally make new ones out of tractor tyre inner tube but these were good.
                        • sal_s2
                          • 1288
                          Nice, can you send me a link to the rubber boots for the balljoints please, I could do with a pair
                            • Dec 2017
                            • 5992
                            I'm not sure if I have one yet. Years ago I bought a kit that had various sizes. I will need to check as I think I may have use all the S2 sized ones.
                              • Dec 2017
                              • 5992
                              I will need to check my stash.
                                • Dec 2017
                                • 5992
                                Today I had a play at zinc plating.
                                Simple set up with vinegar distilled water and salt using zinc strips.
                                Charging the mix with zinc
                                Then plating.
                                It's meant to take 5 mins but was still not finished after 2 hours. I think I need to add a heater as it's so cold in the garage.
                                Now. These spacers. Are these RS2 specific? They seem to go on the hub bolts.
