My silver RS2 Project
    Originally posted by Ian Simmonds
    The after run pumps become brittle with age, it's basically a washing machine water pump. The inlet outlet pipes collapse with over tightening. That's my experience, if it's confirmed that is the problem, just replace it.
    our S2's failed years ago and 'after run' dumped the entire coolant system over Bombardier Chart Leacon's staff car park..
    They can also go bang and spray hot coolant in your face while you're standing over them looking for the leak..
      • Dec 2017
      • 5986
      Cheers Ian. I normally replace the pump anyway when doing a full re build. The original looked quite new and tested good so I didn't on this occasion. New Bosch pump ordered this morning.
      • hashluck
        • Jan 2020
        • 108
        Do you have part number/source for this pump assumng it is same for ABY S2
          • Dec 2017
          • 5986
          034965561c
          • Rikki Kitto
            • Feb 2010
            • 6276
            I heard a rumour that VW Transporters have the same after run pump but much better price
            • John.
              • 2615
              I heard that a washing machine part can be used ?!
              • Rikki Kitto
                • Feb 2010
                • 6276
                Maybe so, these cars are strange sometimes when it comes to sourcing parts
                • K Simmonds
                  • Dec 2007
                  • 7627
                  The Transporter one is very simalar and is plug and play, however it's an inch so shorter so will only fit properly in the one rubber mount. I used one on my 3B as it was half the price from TPS and I couldn't be bothered to send it back.
                  1990 B3 2.0 80 quattro.
                  1992 C4 2.8 Avant quattro
                  1994 MTM RS2.
                  1998 B5 TDI quattro Sport.
                  2000 B5 TQS.
                  • K Simmonds
                    • Dec 2007
                    • 7627
                    It is actually a washing machine water pump or at least based on one made by Bosch, the washing machine version I've seen is all white platic as opposed to black but otherwise the same, I have no idea if the black plastic is in someway stronger for auomotive use or just a different production run.
                    1994 MTM RS2.
                    2000 B5 TQS.
                    • John.
                      • 2615
                      The heat cycles are going to be a bit more "extreme" compared to a washing machine, I'd happily fit a Transporter one .
                        • Dec 2017
                        • 5986
                        I've ordered the Bosch pump that fits many vag cars. I will post a pic when fitting. From memory it is not plug and play and as Kit says the mount has to be adjusted as it's slightly shorter.
                          • Dec 2017
                          • 5986
                          The Bosch pump arrived.
                          But I won't be fitting it just yet.
                          I still have poor starting and rough running until it warms up a bit. I've also noticed an unusual amount of steam from the exhaust each cold start. Unfortunately, I know what this usually means. Sad face. Had it before on an Audi 80 1.8.
                          So
                          No easy way to swallow this. Cylinder 4 and 5 are loosing pressure.
                          I've just checked my bill from the engineering place and no where does it say they tested the head. My fault really for not asking. I just assumed they had.
                          So just got to bite the bullet and get on with it.
                          They are closed tomorrow but I recon I will have it there first thing Monday morning.
                          My trip to Germany in May is looking doubtful. Very sad face.
                          • K Simmonds
                            • Dec 2007
                            • 7627
                            That a bit of a bummer, are you sure the head is leaking as opposed to the rings not being quite bedded in? I'd be tempted to give it another good heat cycle and take the revs up to at least 5K for a few mins before pulling the head.
                            S2 head's are pretty resilient to cracks around the spark plug holes and they don't normally leak.
                            Are the leaking cylinders the ones you had to find replacement pistons for?
                            I think I'd still go to Germany in my Nothelle if I was you, a break would be welcome, you've done well to get as far as you have with the RS2.
                            1994 MTM RS2.
                            2000 B5 TQS.
                              • Dec 2017
                              • 5986
                              Cheers Kit. Good advice. I'm not 100% sure whats going on. I'm going to remove the rocker cover and test again and try see what's happening. Cylinders 1-3 have good compression. Only one piston was replaced and it was like for like.
                              The purpose of the trip was to give the Rs2 a run and take it back to it's birthplace.
                              • Pibbow
                                • Jul 2022
                                • 70
                                • Home: England Current: Scotland
                                #450
                                Sorry to hear this David. I feel our pain but at least you have an idea of the problem and the knowledge to fix it!
