Caddy side project
    • Dec 2017
    • 5991
    All the boost pipes and engine loom are sorted.
    2026-10-16_16-15-46_771.jpg The pesky slave is still leaking. I used a nice flat piece of metal sheet and some fine sandpaper to try and sand the mating surface flat but it didnt work. I think the thread has been cut into the slace at a slight angle so its never going to work.
    I did some research and found the kit uses Goodridge 600 hose. A quick call to Merlin Motorsport and they were able to supply a flared fitting for the slave that i can connect to the pipe. It should come on Tuesday. Retrofication have not been any help at all, failing to respond to any of my emails.
    • RedV6
      • Jun 2026
      • 70
      That is looking really neat. Maybe time to try another slave cylinder. What ever happened to clutch cables....! Oh yea, they pulled thought MK1 bulkheads, I seem to remember.
      • sal_s2
        • 1288
        Where are you going to mount the fuel filter? Doesnt the washer bottle fit behind the headlight?
          • Dec 2017
          • 5991
          Fuel filter is going right side of engine bay a bit further forward than it was originally. Washer bottle goes left side of engine bay infront of coolant bottle. Everything fits ( I hope).
            • Dec 2017
            • 5991
            Next job was to mount radiator and custom fan. There isnt space for the original fan and cowl and i had to move the radiator back and over slightly.
            2026-10-20_13-51-14_112.jpg 2026-10-20_15-04-59_216.jpg I'm waiting for some custom hoses to connect up the radiator.
            2026-10-20_15-05-28_262.jpg Next job is to sort the inside wiring and mount the ecu.
