All the boost pipes and engine loom are sorted.
2026-10-16_16-15-46_771.jpg The pesky slave is still leaking. I used a nice flat piece of metal sheet and some fine sandpaper to try and sand the mating surface flat but it didnt work. I think the thread has been cut into the slace at a slight angle so its never going to work.
I did some research and found the kit uses Goodridge 600 hose. A quick call to Merlin Motorsport and they were able to supply a flared fitting for the slave that i can connect to the pipe. It should come on Tuesday. Retrofication have not been any help at all, failing to respond to any of my emails.
