Caddy side project
    • Dec 2017
    • 6003
    Ok, I came up with a solution. Gear change cables wrapped and high temp heat shield material bonded to the underside.
    2026-09-18_11-03-13_739.jpg I had to remove the oil cooler to fit the front engine mount.
    2026-09-19_09-18-56_201.jpg 2026-09-19_09-19-05_927.jpg Downpipe got re fitted. Its tight but i think it will be fine. Both drive shafts now also fitted.
    2026-09-19_11-29-38_439.jpg 2026-09-19_11-29-23_108.jpg The dreaded downpipe top rear nut! Aaaah
    • K Simmonds
      • Dec 2007
      • 7632
      Was going to suggest lot's of heat shielding for the selector cables but you've already done it, nice work as always Dave.
      And I must invest in some crows foot spanners! Save's so much time making custom tools, plus I've just about run out of spanners I don't like to chop up and modify.
      1990 B3 2.0 80 quattro.
      1992 C4 2.8 Avant quattro
      1994 MTM RS2.
      1998 B5 TDI quattro Sport.
      2000 B5 TQS.
      • sal_s2
        • 1289
        Cant remember, have you already got a modified loom?
          • Dec 2017
          • 6003
          Yes. Loom was modified by friend of friend who does conversions. ECU de immobilized and tweaked a little
          Slow on updates as busy with family stuff.
          Waiting on coolant hose parts to make some new ones up as well.
            • Dec 2017
            • 6003
            I've made a little progress. Plumbed up the clutch. Made a little bracket to mount the reservoir.
            But for some reason i have a leak where the banjo connects to the slave. I've tried new copper washers. Might be an uneven surface on the slave? Bloody annoying.
              • Dec 2017
              • 6003
              The intercooler recommend is massive! Wouldn't look out of place on an S2.
              2026-09-27_19-00-01_423.jpg Its tight but just fits.
              2026-09-27_19-08-30_454.jpg And very snug with the radiator in.
              2026-09-27_19-11-43_829.jpg Now i need to measure up for boost pipes and custom silicone connectors.
              • ottawa coupe
                • 861
                Try alumunum washers for the banjo? They'll be softer.
                1993 UrS4...aka the rocket powered living room
                  • Dec 2017
                  • 6003
                  Excellent idea
                    • Dec 2017
                    • 6003
                    Sorry guys for lack of updates but been busy clearing my mums house as she recently moved into a very nice care home. Back at it now. I haven't fixed the slave issue (yet). I tried new aluminium washers but it was still weaping. I guess i will need to get another slave.
                    Then I found that i needed to clock the cold side of the turbo. Apparently, this is best done with turbo off the car so all the parts i recently fitted need to come off again in order to get access. Doh!
                    Anyway, this gives me an opportunity to clean the intake manifold which is seriously clogged up with carbon gunge. I'm deleting the EGR so it won't happen again.
                    • RedV6
                      • Jun 2026
                      • 81
                      Apologies for being thick! But what is "clocking the cold side of the turbo?"
                        • Dec 2017
                        • 6003
                        The outlet is pointing in the wrong direction so I need to loosen the housing bolts and rotate it 1/4 of a turn.
                        • ottawa coupe
                          • 861
                          For the slave, shouldn't it be a flare fitting anyways? Could also try to flatten the surface with paper and a solid bit of steel.
                            • Dec 2017
                            • 6003
                            I'm using this conversion kit from Rectification. Probably was originally designed for a flared fitting.
                            • johne
                              • Apr 2007
                              • 1406
                              Last resort is use Dowty washers. You can get them with the rubber part suitable for brake fluid.
                                • Dec 2017
                                • 6003
                                Thanks, will try that.
                                spent the day on the car today. Turbo out in the morning, clocked to the right position and replaced in the afternoon.
                                While i was there i wrapped the downpipe.
