Caddy side project
    • Dec 2017
    • 5983
    Onto the rust on the windscreen surround.
    Repair sections are available and we are cutting one down to fit the rusty bits.
    It needs a little more grinding down.
      • Dec 2017
      • 5983
      After some guidance from my friend, I'm solo on the welding now. Getting the welder set for the thin metal was half the battle.
      I've also been following Fitzee's Fabrication on YouTube. He recommends making repair panels on the car before you cut anything out and I have found this very useful. Some excellent advice and guidance in his channel.
      Next bit is the rear window. A fiddly spot and also this area has a dent.
      Panel had already been shaped before this was cut out.
      And welded in.
      Ground back and primer
      And onto the next bit
      Finding just the right thickness card helps
      • K Simmonds
        • Dec 2007
        • 7627
        Originally posted by Tractor Dave
        Thanks Kit.
        I've not made a final decision re colour. The car did come with a new 5l tin of the original green so I'm tempted to use that and save a few pounds
        5L will easily do the whole thing once thinned down, as long as the can is sealed and the paint still live I'd seriously consider this option as it looks like a nice green anyway and more importantly retain originality. Though that a decision that's entirely up to you, a good mate did his in Helios Blue which is another great colour from that era and looked really nice or there's Lhasa Green which was a very popular MK1 GTI colour, a bit like Oak green just a shade or two lighter.
        Nice bodywork BTW, and yes making repair panels before cutting the old metal out make a lot more sense and saves a lot of time.
        1990 B3 2.0 80 quattro.
        1992 C4 2.8 Avant quattro
        1994 MTM RS2.
        1998 B5 TDI quattro Sport.
        2000 B5 TQS.
        • sal_s2
          • 1287
          lhasa, dragon, ragusa, oak, mallard (escort cosworth), imperial ( lotus carlton) or classic green (rivage). All great colours
            • Dec 2017
            • 5983
            This is called a side project as it's one I can neglect for a week or two without feeling guilty.
            Anyway, after a break I'm back on the welding.
            Onto the load area. Unfortunately the company making bed repair sections are out of stock and don't seem to be in a hurry to make any more. I will do my best to patch where possible.
            There are a few rust patches.
            Here we go. First patches in.
            • ottawa coupe
              • 851
              Ambitious me says the only sensible answer for the bed rot is a mid engine swap
              1993 UrS4...aka the rocket powered living room
                • Dec 2017
                • 5983
                Ok, little update.
                I wasn't 100% happy with the bed repairs.
                To do this properly I needed some repair sections. I had been waiting for some weeks for it to come back in stock with Rectification to no avail. However, it did just come back in stock at VW Heritage so I ordered a sheet.
                It wasn't cheap but quality is great and it has made repairing the bed much easier. Now I can get all the welds away from the folds.
                We start over again.
                Another day or so and the welding will all be done. Smile
                • John.
                  • 2615
                  Looking good
                    • Dec 2017
                    • 5983
                    The bed repairs are all done.
                    My welding was slowly improving as I went along. The last couple of sections look quite good.
                    I had to patch the support rail here.
                    I have one small repair to do on the rear hatch frame then all the welding is done.
                      • Dec 2017
                      • 5983
                      At last I got some Novol Protect epoxy on the underside.
                        • Dec 2017
                        • 5983
                        I did two coats yesterday then flipped the car and did two coats today from the other side.
                        Engine bay tomorrow.
                          • Dec 2017
                          • 5983
                          The engine bay took a lot of cleaning. I did it a few months ago and treated the rust but it had started to rust again so I had to re do everything puff puff!
                          Then everything got de greased
                          Bilt hydrate 80 then lunch.
                          Lunch followed by two good coats of Novol epoxy.
                          Then onto some seam sealing.
                            • Dec 2017
                            • 5983
                            The nice warm weather is helping progress.
                            Next step, some underseal.
                            I've used this before and it gives an OE type finish.
                            I warmed it up in some hot water.
                            Goes on lovely.
                            • sal_s2
                              • 1287
                              Ive used that gravitex aswell, good stuff and easy to apply
                              • Davi123
                                • Feb 2016
                                • 98
                                Wow that's looking great Dave.
