Ok, I came up with a solution. Gear change cables wrapped and high temp heat shield material bonded to the underside.
2026-09-18_11-03-13_739.jpg I had to remove the oil cooler to fit the front engine mount.
2026-09-19_09-18-56_201.jpg 2026-09-19_09-19-05_927.jpg Downpipe got re fitted. Its tight but i think it will be fine. Both drive shafts now also fitted.
2026-09-19_11-29-38_439.jpg 2026-09-19_11-29-23_108.jpg The dreaded downpipe top rear nut! Aaaah
