20V CQ Tidy Up
But under normal operating conditions you'll only see peak pressure when something is wrong or maybe from cold, right?sigpic
1976 RD250E / 350LC cafe racerComment
I was thinking about this earlier and I guessed the pump must begin to produce excess flow/pressure somewhere before the peak torque of the standard map? I guess that would be the point of the rpm range where most force was exerted on the bearings?
Imola B6 S4 AvantComment
I dont know what pressure it peaks at as i've never plumbed a proper gauge in. But i suspect it opens instantly on a cold engine, or anything over 2000rpms on a warm engine. Or to put it another way if the dash pressure gauge pegs at 5bar, i would lay money its bleeding off excess pressure.91CQ20v - Gone to a new home
93UR-S4 - The Magic Carpet
94S2Bus - The Emerald ExpressComment
Too much oil pressure will push the tappets out and you will loose compression. Iff more than 5...5,5 bar cold...not ok.Comment
It used to be fairly common practice to shim to get more oil pressure, a few engine building books still mention it.
Does vaseline just dissolve in oil then?Current-2004 Impreza PPP wagon
Sold ABY-stockComment
2013 Touareg TDI /// #farmenwagen
1990 Cq /// Project: Because RacecarComment
Andy, same as I have seen - all of the blueprinting books I have read suggest shimming the relief valve spring to increase oil pressure and also to pack the pump drives with petroleum jelly for instant oil pickup. I'll measure this shim washer in a bit.
It will be an upgrade for 3B owners for sure, as its not there to begin with
Yup its petroleum jelly in both books I am reading just now.
Is the pressure relief valve otherwise identical on 7A/3B, they just shimmed in on AAN?
Something else to do then? Or as the car was fine previously don't ****** it about?Current-2004 Impreza PPP wagon
