And another stroker...(90Q) Goal: 600 HP
  • Big Lee M
    • 2571
    In the words of a stupid but funny film(fast and furious) "That an amazing machine"
    I don't know why i quoted this film please don't bann me from the forum i don't mean it
    Just some finishing touches to do now
    • bsh
      • Aug 2007
      • 43
      • Country: Norway
      #47
      Ok, so I have now sold the Haltech, and ordered a Vi-PEC ecu. Ray Hall from Autronic, have got his own ecus, and it looks VERY promising and a VERY good price: http://www.vi-pec.com/page_files/V88.html
        Any updates?
        • bsh
          • Aug 2007
          • 43
          • Country: Norway
          #49
          Sorry, not yet. Have got the Vi-PEC ecu, but have not installed it yet. Have become a dad now, and do not have as much time to spend on cars right now. Have also been a little busy with mapping customer cars, and installing a new clutch and Vi-PEC in my Evo 2.
          Had a hope to compete in a dragracing event at Gardermoen, but are invited to a wedding the same weekend, so I dont have any particular date to be ready with the car.
          • bsh
            • Aug 2007
            • 43
            • Country: Norway
            #50
            Ok the car is now up and running with the new Vi-PEC ecu Started at first try.
            Have had problems with alot of pressure in crankcase, so must sort that out before pushing it on the dyno. Will try to file a new set of rings with 0,05 mm less gap, and break it in nicely. Hope that will solve the blowby problem.
            • bsh
              • Aug 2007
              • 43
              • Country: Norway
              #51
              Found a broken ring (2nd ring cyl 3). Will fit new rings and hope my problems with high crankcase pressure are solved.
              • bsh
                • Aug 2007
                • 43
                • Country: Norway
                #52
                The car is now up and running again with new rings Must break in the new rings, and then it is time to push for the 600 whp on the dyno
                  Originally posted by bsh
                  Also had to cut a little in the bonnet to clear the intake
                  You had to cut it that much?
                  Wow!
                  • AndyP
                    • 6049
                    RS2 manifold it is then
                      Just realised it's not an S2, phew even so!
                      • bsh
                        • Aug 2007
                        • 43
                        • Country: Norway
                        #56
                        No I did not have to cut that much, but the bonnet were already destroyed by the previous owner, so I didnt care. It had no "storm hook" (directly translated from Norwegian) and when he was out driving, the bonnet opened and destroyed the window
                        • Jeffer
                          • 2057
                          Wow!
                          It's haunting you isn't it Jamo :mischeif:
                          RS2 Black - stock 315 HP
                          RS2 RS blau - stock 315 HP
                          Sport Quattro - 1005 HP
                          High Octane website
                            Your enjoying this aren't you Jeffer
                              Any updates on this project?
                              • bsh
                                • Aug 2007
                                • 43
                                • Country: Norway
                                #60
                                Yes actually I have finally managed to break in the rings (yes it took me about a year to drive 1000 km....), and I have the car at the dyno right now. I will first map it on pump fuel and then I will fill it with E85 and make another map for it. It will take a little time as usual because I will do alot of logging and I will also be testing several different knock devices, including the internal Vi-PEC V88 knock sensor circuit which is even able to detect which sylinder that knock and pull timing from that cylinder only.
                                If it surives the dyno, I will post some pictures of car and dyno sheet when finished
                                Thanks for showing interest in my project
