Can't wait to see her "alive"
Audi S4 small drag project
I still have not seen the car directly, but the floor on the rear got modified for fiting the fuel cell, as seen here
but that was not the final version, and about the rear ride height it seems quite high, but we are going to see how it behaves on launches. If everything is fine, tuesday the car will be on the dyno for run in, and settings
The car got the run in, made, and the first software made , by Miki. There was some leaks at the intake manifold, and only used 1row / 1 pump setup . The result was aprox 500 hp (crank), at almost 1.1 bar boost, and a rpm limit around 7200 rpm, i'll post a dyno later. I'll have to get use with the car , as going from 280hp and 1.7 tones, to 500hp, and 1.2 tones it is a big differences
Today was the first try of this car, and the first ever drag strip for me, i have to say that is a very exciting thing, and first full throttle on third where boost hits you like a train
, with idle launch
. The engine runned without problems, but i broked the rear driveshaft (stock one), on second launch, i was trying to launch a little harder. The good thing is that i was expecting that, and probably i will find soon a much better solution - driveshaft / tyres combo.
http://www.youtube.com/watch?v=wFKNE448Di0 - sound check .
Getting to know the car
, and trying not to hit the rev limiter to often
