audi rs2 -94 500+ project
  • lind4hl
    • Jul 2008
    • 2465
    Did get some free time tonight at my mates workshop with some nice tools that i dont have..
    So i have Glass-blasted the rocker cover and then weld on the AN- fitting and after that 30min in an "hotwasher"
    Nextup is to get some 1,8T coils so i can measure up how much i need to mill on the rocker cover/ drill up the holes, and after that Red wrinkle paint time
    • rs2coupe
      • Oct 2004
      • 1782
      • Home: Trinidad and Tobago Current: United States
      #212
      Hi mate a bit off topic but would you happen to know if the rear control arms in "cast version" is available to buy new? not the stamped version!
      Cheers mis amigos,
      _Anton
      • lind4hl
        • Jul 2008
        • 2465
        hmm, they might be? why would you want them?
        • rs2coupe
          • Oct 2004
          • 1782
          #214
          Looking to build a nice 90 quattro for my Father. Got some VAP acetrone GP bushings for the cast front and rear arms.. found a used set but the price is $95 per piece... just curious what the new cost is!
          Cheers mis amigos,
          _Anton
          • lind4hl
            • Jul 2008
            • 2465
            you could use the pressed versions also, just change some bolts to longer
            • lind4hl
              • Jul 2008
              • 2465
              Update i took the camera with me, but no battery so you will get mobile pics..
              I concered the mat! hurray
              why the hell audi did this nut??
              This is how the rear floor looks on the drivers side now, just painting left..
              this is how much i have been taking off from the car, approx 15kg i think, and there is little more left, but i got so tired of it..
              and got the Torsen out
              now it will be a time until nest update.. installing an Toyota supra Rear axle onto an Volvo 244
              • lind4hl
                • Jul 2008
                • 2465
                Update
                Ordered new Bilstein front shocks today, so next week i can start to get the front suspension fully assembeled
                and carbotech xp10 brakepads are ordered, also going to refurbish my calipers soon.
                and the big bomb!, since you only can run 8,5" wheel on these cars and my car needs at least 10" rims so i can run with wide tires when i am at the trackdays, these will be ordered for the front:
                some people might hate me, i think it is going to look awesome! in the rear i am also going to make the car wider, dont know how yet though...
                so next weekend plans:
                Get the topmounts welded in with more caster
                make the coil-over for the strut
                order springs for front coilover
                start looking on Front brake cooling
                And hopefully trial-fit the Front fenders
                • ciaranthemurph
                  • 696
                  Originally posted by lind4hl
                  Got some parts delivered today
                  034ms camber/caster plates
                  some different sized decals
                  and 2 034ms shirts
                  im soon going to order new shocks all around. bilstein adjustable fronts.
                  and some coilover shock at the rear to make it easier to build the coilovers. just need to remake the upper spring seat @rear.
                  built for 2,5" coilover spring and bilstein shock.
                  Looking forward to seeing how you get on with fitting these. Not that fussed about more pictures of your feet though .
                  Respect for having the courage to strip such a car!
                  • lind4hl
                    • Jul 2008
                    • 2465
                    hey! no wrong with my feet
                    i will start mount these next weekenc
                    • lind4hl
                      • Jul 2008
                      • 2465
                      did some work today
                      First of all, refilled the torsen rear diff and put it back up with new bushing at front
                      ready to go up again, i am pretty good at this now (4th time )
                      there it is
                      a shame to hide this beautiful bushing really..
                      then i started to remove the front end ( wings, lights front bumper etc) so i can put the new ones on asap.
                      though, some problems, how do i remove the front fender, i have removed all bolts exept 2 that is sitting at the bottom rear on the fender, under this trim, how do i get it loose? does it slides on as the door trim??
                      and what is this for? gies a hose in the wheel arch and then to this valve and then in through where the AC tubes join in the firewall?
                      • lind4hl
                        • Jul 2008
                        • 2465
                        woho!!
                        • Skull
                          • 3506
                          • Country: Slovenia
                          #222
                          where are the rears??
                          Audi Quattro WR
                          • lind4hl
                            • Jul 2008
                            • 2465
                            the rears will be something different... only bought fronts from an swedish dealer, so nothing from the other place..
                            for the rear it will be Nitron 2way adjustebla valved for my spec or something similar
                            • Skull
                              • 3506
                              • Country: Slovenia
                              #224
                              so you got nothing from STG??
                              Audi Quattro WR
                              • 4WheelDrifter
                                • Oct 2004
                                • 5773
                                • Country: Devon
                                #225
                                That's a non-return valve for the AC recirculation function. One hose goes into the wing where there is a vacuum reservoir, the other goes to the recirculation actuator.
                                SS
