I agree. I'd avoid using stainless on suspension/brake parts, its soft as ****.
audi rs2 -94 500+ project
I'm gonna try Hammerite for this purpose. Hope not wrong choice as well.Comment
artis: that would also work
today the camera struggeld, so no pics
but i got done some things today:
bolted up intercooler + crossmember (going off when engine should go in, but i mounted it anyway
long time until engine going in again)
bolted up 034motorsport gearbox mounts
And i bolted up the whole t pipe for brakelines on rear subframe (huge amount of work
just need to fix some tools to take out the plug in rear diff and change oil, and then bolt that up
One thing i've learned we are way behind the Scandinavians!Comment
OMG, which company did you "use"?
Would be good to know so that I never leave my stuff there
OT:
Ok, no worries..Audi S2 -1994 | 480 Hp 650 Nm | FlexFuel | MaxxECU | 3" Stainless | Porsche GT3 Front Brakes
http://www.garaget.org/?car=52877Comment
new sick plans agin
to fit my 9" centernut wheels i maybe make my own controlarms with some mm less trackwidth, i am going to buy new driveshafts so i can easily make them shorter.
then rear axle will be uniballs everywhere
i will measure under the weekend
small update
i bolted up the rear diff last weekend, only need to change the front diff bushing when i have bought it.
new redline gl5 oil in the diff also
not so much money left for the car atm . will be father in 4 months, so money is on other stuff.
soon i will order the powerflex bushes for the wishbones though.
and new cv joints alla around
some pic´s
diff came a little higher up after installing the alu subframe bushes ( for better lower arm geometry)
and a question, the black/yellow vacuum hose should sit nearest the diff or?i have a weak memory of that, the note i wrote it on are missing
New CV joints?
Save your money, they last just about for ever! I have never replaced one! The ones on my UR are original, 250,000 miles and only changed one boot...
Rob..
87 UR 20v ABY
97 S6 Avant
1967 Ford Mustang,Eleanor,460ci v8Comment
Update
got some work done some days ago. took out the crank, oilpump etc, the engine were in really good condition.
some pics:
vag tool mounted, my friend work at the stealer and this bolt is the tightests he have undone
off and away
oilpump gone
the crank:
i don´t know the word, but now they are gone, took some time before i understood how to get them loose
now it´s lying nice and cosy with original pistons/rods/oilpump and some other bits waiting to be refirbished
head, waiting to be ported and polished´etc.
anyone need an dual mass flywheel/ rs2 pressureplate and cluch (9mm thick)??
(jamo
