cause, i got this so freakin cheap, so i couldn´t resist, i dont need it in a ½ year but if you pay a quarter of the price so
audi rs2 -94 500+ project
if anyone intrestd, i have now ordered 034 alu rear subframe bushings, and will order there upper a-arms with uniballs when these are finished (for more camber/caster) also the last bushing: apikol front diff mount, so happy to let go of all these bushings now! only the brakes, sus*****on and engine left
Little update now.
the things that should be powdercoated getting sandblasted next week and painted with 2k carpaint instead, cause at the powdercoater there is nothing happening
but i took out the beast today, and washed the enginebay and mounted the 034motorsport enginemounts
dual mass flywheel should be illegal
some (crappy) piccy´s
engine, maybe strip it during the weekend and start to paint the bottom end, also glassblast all alu parts
enginebay looks pretty good now.
finally some work done!
i have now got all parts painted with ca primer and black 2k paint.
the finish is awesome for painting it in the garage, big thanks to my personal painter
all new parts are bolted up with stainles steel bolt, locknuts and lockwasher+regular washer.
som pics
sandblasted
CA-primer
front subframe
overall pic
some hours later, black
rear subframe,
and 2 pics on rear subframe with whiteline rarb and the reinforcement brakets, (i am ashamed over how dirty the car is under
dont know if the rarb is on the right way, dont remember, but no big deal to twist
front subframe is also bolted up, but will take pics of this tomorrow + crossmember with ic, hopefully gearbox mounted then also, next up is:
change oil in rear diff + bolt up with stainless bolts locknuts etc.
bolt up prop (new bolts V.A.G)
make my own upper rear a-arms + motre adjustable toe woth uniballs.
order polybushes to control arms + farb (no delrin )
I thought you were having your parts powder coated?
Looks good thoughAudi S2 -1994 | 480 Hp 650 Nm | FlexFuel | MaxxECU | 3" Stainless | Porsche GT3 Front Brakes
http://www.garaget.org/?car=52877
Its a bit of a no no stainless bolts on suspension.. I have never seen any but, apparently with the stiffer stainless steel they can crack and fail...
Just a thought for youRob..
87 UR 20v ABY
97 S6 Avant
