My Audi S2 600Hp+ project 56k warning
This topic is closed.
  • terrybullwon
    • Mar 2006
    • 8782
    Originally posted by lind4hl
    what am i telling you James?? pictures,pictures!!
    Just for you mate
    Chef
    • terrybullwon
      • Mar 2006
      • 8782
      Chef
      • lind4hl
        • Jul 2008
        • 2465
        Welds looking pretty good there
        but what the hell have you done with the bend @ turbo????
        are you going to weld anything more there? or a wiggins maybe?
        • lind4hl
          • Jul 2008
          • 2465
          saw now.. you cant use a silicon piece there.. it will blow loose in seconds.
          also, at the mushroom filter, do a weld 5mm from the edge so you get an higher edge that holds the clamp back, got it?
          • terrybullwon
            • Mar 2006
            • 8782
            Doubt i will use a wiggins, I think i will just weld it Monday
            Chef
            • lind4hl
              • Jul 2008
              • 2465
              weld it, that is fine!
                nice work mate did you weld the ally yourself?
                could you use a v-band on the intake side?
                • lind4hl
                  • Jul 2008
                  • 2465
                  • terrybullwon
                    • Mar 2006
                    • 8782
                    I am having lessons
                    Its bloody hard to start getting there now, lind4hl gave me a few tips to.
                    i think i will just weld it, need to stop spending money and drive
                    Chef
                    • lind4hl
                      • Jul 2008
                      • 2465
                      did you understand what i said @ the airfilter?
                      • terrybullwon
                        • Mar 2006
                        • 8782
                        Yep
                        Chef
                          Its only vacuum there so its not going to blow off is it.
                          • dubmeister
                            • 522
                            TURBOS SUCK!!!!!
                            • G60Rallye
                              • Dec 2006
                              • 1321
                              Nice looking progress, great to see you are doing so much of it yourself!
                              That blue focus is Andrew Gallachers car and I am pretty sure he made it himself didn't he Jonnybravo?
                              • prosty
                                • Jun 2005
                                • 1114
                                You don't even need a clamp there just the hose, it's just suction not any pressure at all, but ofc you should always have a clamp there, if you weld it to the intake pipe, servicing will be a PITA.
                                Just go with a silicone straight connector the same color as everything else under the bonnet to match. It will be fine. I promise
                                2004 9-5 aero
                                2009 Subaru Legacy Diesel
                                1994 Toyota Supra Eurospec 6-spd LHD
                                3-4 Audis in parts
