My Audi S2 600Hp+ project 56k warning
This topic is closed.
It was so far away from the car I thought it was a shelf on the wall
Dry sump tank mounted, water pump mounted, fuel cell mounted, radiator collector mounted, Inside sprayed white, water plumbing done, naca ducts done.
S2 Wot has kindly sent some ducting clips so i can tie all that in
Cheers for that shane as you can see the ducting does not really want to stay up there
ChefComment
