3b s2 coupe resurrection
  • andy10v
    • 5996
    Originally posted by twoqu
    Have you got another fuel pump relay to substitute?
    Sounds like quite a large voltage drop from battery to actuators.
    I have tried a spare fuel pump relay.
    It will spin the engine over at good speed no bother, are you thinking something may be rather voltage sensitive?
    Sold ABY-stock
    • andy10v
      • 5996
      Where does 30/55- Ground for ECU and ECU sensors - G/BK (See details with a listing of the seven devices grounded through Pin T55/30) go?
      Sold ABY-stock
      • andy10v
        • 5996
        18/55- Constant power supply to ECU J220 - R/R- from power terminal 30 (+12V) Fuse S26 (5A) - passenger footwell as shown HERE, in this above ECU fuse panel call-out post). This constant power also feeds the Holding Relay for its work during start-up and shut-down.
        Has 12v
        Sold ABY-stock
        • twoqu
          • Sep 2003
          • 3103
          #1204
          Isn't that the main ecu chassis ground? If so its in the footwell I think off the top of me head!
          To double chec, ,see if there is continuity between the other ground pins and 30. If the injector earth does not have continuity with 30 than that makes sense!
          • andy10v
            • 5996
            27/55- Switched Power to ECU from power (+12V) - BK/G - from Terminal 15 under the knee bolster - 15A circuit breaker, BK in BK/G out - S64
            Has 12v with the ignition on.
            Sold ABY-stock
            • andy10v
              • 5996
              That is what it reads like, I will pop off the glovebox and have a look.
              Thank you for your patience
              Sold ABY-stock
              • twoqu
                • Sep 2003
                • 3103
                #1207
                We need power and earth. So if you don't have one or the other then thats an issue that needs investigating. Although if the ecu itself is not grounded I am surprised some of the output tests worked. Still it sounds like a probable cause.
                • andy10v
                  • 5996
                  Pin 33 is black with a purple stripe, it goes into the top group of connected wires (I presume a collection of earths?)
                  Sold ABY-stock
                  • andy10v
                    • 5996
                    The loom then goes up behind the heater box and I cant see where that group grounds.
                    Is it worth grounding pin 33 or the whole lot to the chassis?
                    Sold ABY-stock
                      Grounding points behind dash are usually quite high up on the A pillar, a bolt with a load of rings on, sometimes these go rusty where water drips down.
                        If you're sure that pin is supposed to be grounded then why not try grounding it!
                        BTW it could be driver's side A pillar.
                        • andy10v
                          • 5996
                          I am not clear if 33 is a ground, or a ground reference? This diagram does not show it as a ground, but a 0V reference signal.
                          Sold ABY-stock
                          • andy10v
                            • 5996
                            Cheers, got them to the left of the heater box.
                            Sold ABY-stock
                              Actually in this diagram it shown as not connected I think, it's a bit small on my laptop..
                              • andy10v
                                • 5996
                                Because I dont want to break something.
                                I am not sure if it is a ground? Daves list says
                                "30/55- Ground for ECU and ECU sensors - G/BK (See details with a listing of the seven devices grounded through Pin T55/30)"
                                Which makes it sound like the ecu uses it as a ground, the above diagram makes it look like its part of a signal circuit? S2central says it is a 0v reference signal for a pile for F96 , G42 , G61 ,G62, G66, G69
                                Sold ABY-stock
