My 95 S2 Avant Project. LZ5T Coolness
  • irishs2
    replied
    Thanks all
    mdz, I did try a plastic primer but it just scratched off, maybe I have the wrong one. Not gona give up
    If I cannot safely tap the wheel sensors from the abs unit I might have to rethink my plans lol
    To be honest its a little diversion before tackling the process of putting the engine back together.
    Didn't the earlier cars have the difflocks on the dash?
  • restricted
    replied
    after seeing that I have decided to up my stake, call it a full packet of Oreo's and half a packet of fizzy cola bottles!!!
    One criticism (of Audi not you) why in god's name did they put the diff lock out of site... I want to see the lights when it slips lol
    Hats... off... and muchio impressio of you sir... I really like that
  • mcandmar
    replied
    Very cool. Now all you need to do is monitor the four ABS sensors to indicate wheel spin
  • mdz
    replied
    Originally posted by irishs2
    Pity about the seat belt adjuster, its polypropylene, and none of the paints I have will stick properly to it.
    I used plastic primer and just regular matte back paint. 3 years since painted and it still holds. Same with grab handles and sun visors.
  • irishs2
    replied
    Finished off most of the fabric based work over the weekend.
    Recovered all of the pillars edge trim in fake black suede.
    Also got my little diff lock board up and running.
    Quick and dirty test program with fades and disco mode.
    Something a bit tamer.
    Now on to more serious things, like engine and gearbox reassembly.
    replied
    Thanks.
  • irishs2
    replied
    Sorry I ment to address that question directly as above, yep I do, both boards should fit. Just to be on the safe side, you can print the above PDF, and cut it out and place it over the diff lock , it should give you an idea of its fit.
    replied
    It might be too early to say but do you think this would be the same as the URS4 difflock as i am interested in retrofitting it to my URS6.
  • Michael S2
    replied
    Awesome work as usual
    I have some bulbs blown as well may be interested in this as well if you do decide to make some up.
    Keep up the good work
  • irishs2
    replied
    Will do, I will start a sale thread when I have a product. Its still very early days. Although I did manage to get the microprocessor up on running on the pcb with a string of addressable leds, so thats always a good start.
    According to this
    The insides look the same, so I have attached a pdf that can be printed out 1:1 and cut along the black line, that will give you the dimensions of the board.
    replied
    Do you think this would be compatible with the URS4 which has the diff lock?
  • rynaqui
    replied
    Me too, I quite like the idea and never use the diff lock myself so it would be useful for something
    replied
    Thanks guys, yea I work in IT. Self employed but sysadmin for several companies blah blah . But I was always into electronics and formally educated in electronic engineering. It has helped me get out of a few jams.
    Yea I will be using addressable RGB leds , 11 on that prototype and will be using gala/ speed signal as an input . Eventually I want to read the abs from each wheel and it will tell me which wheel is slipping or where the power is going ... useless thing but it a gadget. I was always disappointed on how static the diff diagram is
    sounds excellent, count me in if you end up getting some made
  • rynaqui
    replied
    That is some dedication, awesome work!
    replied
    Leaving the oreo thing aside....i would like one but mine doesn't have one (URS6 )
