X is the switched 12v that cuts out with the starter. 15 is ignition switched
Good work mate. I hated messing about with the wiring. It's not that the wiring itself has anything wrong with it, just that the harnesses don't fit... at all. Pain in the ***. I wonder if LHD has the same awful fit.
Yep, whats funny is that there are two clips on the fuse board box that hold the loom back , and they are nearly impossible to do up from below. I might have to lift the fuse boad again and pull the loom up from above. Bit by bit its getting there. Hopefully get the sunroof in next week, I have a new seal arriving from germany, then I can lay the dampening, the carpet, heating and dash back in.
Yes the fusebox lifts out from the top but it does require some care as you can easily break the lock tabs and there is little slack on the mess of plugs on the underside which you have to remove for the swap.
Finished up the wiring under the dash, while it may not look tidy, it is to my eyes
It was such hard work to get it to fit and tie up properly.
New drip tray for the sunroof, mine was missing and no doubt the cause of water ingress.
New ebay.de seal was fitted to the panel. Macspring mentioned that it might be a bit tight, it is but the sunroof still operates and with a bit of working I am sure it will loosen out.
You can see my red testing wires coming down on the left off the sunroof.
