My 95 S2 Avant Project. LZ5T Coolness
    X is the switched 12v that cuts out with the starter. 15 is ignition switched
    Good work mate. I hated messing about with the wiring. It's not that the wiring itself has anything wrong with it, just that the harnesses don't fit... at all. Pain in the ***. I wonder if LHD has the same awful fit.
    • irishs2
      • Apr 2009
      • 2455
      Ah didnt even consider that. 15 it is.
      Yep, whats funny is that there are two clips on the fuse board box that hold the loom back , and they are nearly impossible to do up from below. I might have to lift the fuse boad again and pull the loom up from above. Bit by bit its getting there. Hopefully get the sunroof in next week, I have a new seal arriving from germany, then I can lay the dampening, the carpet, heating and dash back in.
      Eric
      95 S2 Avant under rebuild.
        I never knew you could change the fuseboard like that by dropping it into the car, top tip!
          #379
          Yes the fusebox lifts out from the top but it does require some care as you can easily break the lock tabs and there is little slack on the mess of plugs on the underside which you have to remove for the swap.
          • quattrostyle
            • Oct 2006
            • 6229
            Stop wondering, they are equally horrible. I really don't understand they made such a mess from it in the factory. Other German brands did better IMO.
            • irishs2
              • Apr 2009
              • 2455
              Little update:
              Finished up the wiring under the dash, while it may not look tidy, it is to my eyes
              It was such hard work to get it to fit and tie up properly.
              New drip tray for the sunroof, mine was missing and no doubt the cause of water ingress.
              New ebay.de seal was fitted to the panel. Macspring mentioned that it might be a bit tight, it is but the sunroof still operates and with a bit of working I am sure it will loosen out.
              You can see my red testing wires coming down on the left off the sunroof.
              Sunroof in and closed.
              Next up, dampening and underlay and carpet.
              Eric
                Bet it felt good getting that wiring finished, it is an epic, pain in the *** job! So is that an OEM roof seal?
                • irishs2
                  • Apr 2009
                  • 2455
                  Non oem, I am afraid.
                  This is the one
                  http://www.ebay.co.uk/itm/1511311853...%3AMEBIDX%3AIT
                  The sunroof does move a little slow, but I am operating at 11.5v instead of nearly 14v with engine running.
                  Eric
                    Good to know there is a non-OEM alternative as I believe the OEM ones are NLA now
                      #385
                      That OE wiring is about as tidy as it gets on a B2/B3/B4 - so much electric spaghetti
                      • irishs2
                        • Apr 2009
                        • 2455
                        Sound deadening and carpet time.
                        I used 4mm silent coat, foil backed deadening, 3mm dynaliner and 12mm dynaliner.
                        Template made of paper and masking tape.
                        After some choice locations to place the sound deadener I put down a layer of 3mm liner, also going underneath the duct.
                        Then 12mm was used to build up the difference between the duct and the floor.
                        Before
                        After
                        And carpet in.
                        Eric
                        • rynaqui
                          • Mar 2012
                          • 2752
                          • Country: Malta
                          #387
                          Eric you're almost there, you've done some amazing work and I commend you for turning this car around!
                          1996 S2 ABY Silver
                            Good job on the sound deadening, Its really tough to get everything to fit as the OEM felt was heat moulded into shape
                            • Michael S2
                              • Dec 2011
                              • 1378
                              Amazing work This will be as good as new when back together.
                              All that wiring looks a nightmare. Must be a relief to get all that back in.
                              1995 Audi S2 Avant
                              • ralleyquattro
                                • Oct 2007
                                • 536
                                • Home: Poland Current: Canada
                                #390
                                I vote this thread for a sticky!!
                                www.quattro.ca
                                B2: 82 Urq into Sport quattro, 82 4000 2-door, 83 80q 2 Door, 83 Ur-q CDN, 85 Ur-q Euro with 3B, 86 4kq, 59,000km
                                B3/B4: 91 CQ, 93 90q 2.5TDI, 94 80q avant 2.5tdi, 94 S2 Avant
