Excellent job, some dedication there dealing with the rusty bits!
My 95 S2 Avant Project. LZ5T Coolness
Originally posted by UrS4boy View PostFantastic job on all this Eric. Most people would have run away from this project, screaming, with their aprons over their head (think Monty Python).
Originally posted by Greg_S View PostExcellent job, some dedication there dealing with the rusty bits!
Gearbox time.
Quite grotty looking.
I lost complete track of time doing this.
Measured the depth of the seal again , which turns out to be pointless really as the new seal is a slightly different shape.
Seems to be very red, is that rust from the cast iron section?
Needless to say all that was mopped up, and the magnet was cleaned. I will probably change the oil again quite soon just to be sure.
All cleaned up and painted.
Seal goes in as far as the stop. Calipers was used to verify that I have the seal in square.
Same here
Another seal
Before and after below.
Cleaned flanges
Mounts arrived yesterday, had to 'test' fit them Thanks BambridgeLast edited by irishs2; 7 July 2017, 15:19.
Not much has been happening over the last few weeks, other 'reallife' jobs had to be done, but in the spare hours in the evenings I was able to get a few things done.
Main pulley had rusted so it had to be cleaned.
All cv joints were rebuilt, but the fronts needed new abs rings. The old ones had cracked off. After cleaning they came out ok, got light coat of paint and put into the freezer, I heated the ring with a hot air gun and the ring went on with out trouble. You can still see the condensation on one of the joints.
Starter motor was fine, just mucky looking, take apart, clean and rebuild.
Alternator had seized, so was a bit of fun taking apart. Not much damage just rust on the stator. Bearing were shot, so they were replaced, but the slip ring got damaged when removing one of the bearings, so that was replaced. As was the regulator.
Just a test clean on the throttle actuator.
Stainless M5x50 allen head finish this off nicely.Last edited by irishs2; 7 July 2017, 15:19.
You are a sick person.. this is concourse style restoration.
I would be scared to drive it.
Very impressive. Keep it up.
Cheerswww.quattro.ca
B2: 82 Urq into Sport quattro, 82 4000 2-door, 83 80q 2 Door, 83 Ur-q CDN, 85 Ur-q Euro with 3B, 86 4kq, 59,000km
B3/B4: 91 CQ, 93 90q 2.5TDI, 94 80q avant 2.5tdi, 94 S2 Avant
Thanks. Maybe I am sick lol.
This week was a good week, my head and block are finished.
Collected my bits yesterday, I think they look quite well after glass blasting.
My head was done twice. Only because after the head was done, the engine shop got new blasting equipment, it was taken apart and redone to get the finish here.
New rings, Mains, ACL race big ends, Honed, crank polished, and cylinders honed.
I am a little worried about the excess paint around the oil filter area and return, am I being too fussy or should they really be bare metal.
This coming weekend I am going to try and finish painting my engine bay, fingers crossed.
The blasting is a tale in itself, short version is that yes cork engines did the blasting you see there, they used to outsource their blasting but that company lost my bits for nearly 2 months. by a company you and I know unfortunately, I have pics of the mess they made of my em I was very surprised by how bad it was. That is the outsource company not corkengines. Eventually my bits were found and blasted by corkengines by new equipment they got as they couldnt rely on that company anymore. Many many sleepless nights were had.
Putting it together will be fun, there are bits there that I didnt take off, (bolt lengths assy order etc) , and bits in the victor gasket set that I have no idea what goes were lol. Will be watching error404s build with eagle eyes
The abs rings I was going to get them from http://www.ukpartsdirect.com/, but they are expensive so I though, hell they are abs rings nothing more complicated so I bought them from ebay http://www.ebay.co.uk/itm/150565748744
INSIDE DIAMETER: 63.9 mm
THICKNESS: 8.3 mm
TEETH ABS-RING: 45
Sorry to hear about you'd troubles, I must have been lucky so, all though there was a long wait, but seems like everything is good nick from photos, was the cost reasonable, labour wise ?1991 S2 3B Coupe, KW v1, solid sub frames, poly bushed, chipped, about 260 ish
The have a good reputation, I think I was the unlucky one.
Price I think was fair, considering what was done. The striped the head a second time foc, just to get that quality finish.
This is how the exhust manifold came back the first time, I am not sure a zinc finish on an exhaust manifold is a good idea, certainly not a finish that can be picked off in places with your fingers. took corkengines an hour in their blaster to fix that, and remove that crap finish.
