80Q Competition 20VT inside¡¡
another question for the poeple with experience in this....
for fit the S2 Avant rear diff in the competition, i have to buy too the s2 avant hub carriers and S2 avant rear subframe?? or not?? competition subframe it is Ok? 3B subframe too??
LWB Audi Sport Quattro projectComment
Best go with S2 avant driveshafts and hubs. Also best to go with front subframe from S2/RS2 Avant for easiest fitment of 01E gearbox.Paul Nugent
Rear subframe should be same between original car and S2 avant/limoPaul Nugent
i got V6 front subframe...for intsall in it the RS4 gearbox...that it is still connected to the 600 hp engine¡¡
S2/RS2 AVANT/Limo rear diffs ... are different to the coupe ,Ok i understand it.
but i need too the hub carriers of them
and about rear diff driveshafts...?? can be used the 3B coupe rear diff driveshafts with the S2/RS2 rear diffs??
- Looking for a S2
- Lancia Dedra HF turbo i.e. (4sale)
- Typ89 Coupè quattro, 20Vt AAN, VEMS, K24-7000@1.3bar (scrapped )
sigpicComment
it is a very bad and expensive idea whem you got a pair of complete engines in your garage...... and you have a broken engine in the competition
hahahaha well... I think you are right!
but it wouldn't be a bad idea tho! check out the whole thread, I have just found it! 6 pages, pretty interesting!!!
- Looking for a S2
sigpicComment
hello¡¡
before install every parts neccesary in the 80 competition in the rear like RS2 rear diff + S2 avant driveshafts + S2 Avant hub carriers + S2 3B 5x112 hubs ..... now i am thinking that i will need 5x112 alloys and rear brakes for S2 Avant specs...
any suggestions??
does someone has S2 Avant original and cheap rear brakes??
iw ill need it for drive¡¡ or if not..... I have to buy a S2 Avant rear brake upgrade....
, any suggestion with it?? Pete Reve sells something for s2 avant in the rear like with the coupes??
and what about wheels??
S2 ABY wheels?? 3B wheels?? S6 17"´s?? S8 18"´s?
