Terrybullwon's Racing S2 coupe
This is a sticky topic.
    air jacks?
    • Jonnybravo
      • Aug 2008
      • 2051
      PM on its way James
      • Jonnybravo
        • Aug 2008
        • 2051
        Originally posted by Error404
        air jacks?
        I could do with some of those ! group buy James ? lol
        • quattro84
          • Mar 2006
          • 947
          Originally posted by terrybullwon
          Martin Shakka
          How do you refer to Mr Rallycross..?
          This guys is true magic.
          • Jonnybravo
            • Aug 2008
            • 2051
            • king
              • Nov 2008
              • 200
              Do you know the weight of the car?
              Beautifull project you got !!!
              • Dan
                • Jun 2008
                • 1242
                I hear he tried to weigh it, but every time he put that grain of sand on the other side of the scales, the damn thing flipped right over.
                1993 ABY Coupe | BMW R1200 GS
                A6 3.0 TDI Quattro (aka Sonic's 'ring support/cargo vehicle )
                • quattro
                  • Dec 2004
                  • 768
                  #38
                  Fantastic work all in there james! keep it up.
                  Probably the longet S2 project in history EVER!
                  • Keeper of The Kitten
                    • Dec 2003
                    • 2317
                    James I have to ask about the tall gearlever - I've been toying with some designs for raised levers but with shortened throw, what have you done here? Great project!
                    Martin Cutting
                    • terrybullwon
                      • Mar 2006
                      • 8782
                      Under the shifter tower is an adjustable bush so you can bring the linkage as far up in the tunnel as possible and as you can see the pivot point of the shifter is moved up the shaft so the throw is less than stock at the moment.
                      Also the connections at the gear box are a solid plastic bush at the top section and a syphrical bearing at the bottom connection.
                      The shifter rod is also cut open all shot removed so its lighter and then lengthend by aprox 30-40cm
                      Chef
                      • Jonnybravo
                        • Aug 2008
                        • 2051
                        James YHPM
                        • Bram
                          • Aug 2006
                          • 2582
                          audio samples please :mischeif:
                          • terrybullwon
                            • Mar 2006
                            • 8782
                            Made a little test of the Electric water pump today on my break.
                            Seems to work pretty well, i thought i would be harder to bleed in than this but i left the pump running adding water in as it was taken and it work like a charm.
                            Hes a pretty pointless video.
                            Chef
                            • 4WheelDrifter
                              • Oct 2004
                              • 5773
                              • Country: Devon
                              #44
                              Nice work, as always, Terrance. I like the tour around the cooling system.
                              SS
                              • terrybullwon
                                • Mar 2006
                                • 8782
                                Thanks Stuart.
                                In reflection i wish i run the lines under the car. Its going to be warm on a summers day thats for sure.
                                Chef
