Terrybullwon's Racing S2 coupe
This is a sticky topic.
  • nervas
    • 357
    • Country: Lithuania
    #121
    its better to copy from WRC ... http://www.subaruwrcspares.com/5.html
    Xtra Racing
    • terrybullwon
      • Mar 2006
      • 8782
      Originally posted by nervas
      hi, not the best design of mcpherson control arms.. on braking you will have problems with outer spherical bearings, it can unscrew... If you want to test then put there 2x nuts, but it would be better to have there welded housing for round spherical bearing for safety.
      had similar design years ago.. it works with double wishbone, but not mcpherson
      Okay were try and see.
      Originally posted by andy10v
      Are zip ties not taking the weight saving to the extreme?
      Were you worried about the original diff mount on the subframe flexing? Are the wishbones "set" in the subframe or will you use spacers to adjust back and forward?
      You got a date for the suspension?
      Original diff mount must flex with 600hp thats for sure! This will not 100% and yes i have some one making me several sets to allow adjustment and some special EN36 hardend King pins with alittle extra length to bring back the roll center with the lowered chasis
      Chef
      • Jonnybravo
        • Aug 2008
        • 2051
        More like this you mean :
        Where are you getting your joints from James ?
        • terrybullwon
          • Mar 2006
          • 8782
          Bloody hell James enough nuts on there???
          I got a card off some guy from Autosport for Aurora bearings so gave him a call got a pretty good deal out of it in the end. But you still cringe when you know the price for each joint
          Chef
          • Jonnybravo
            • Aug 2008
            • 2051
            Double adjusters mate, so adjustable in situ as per the works cars. I'm not using Aurora bearings, too pricey for me ! Andrew Gallagher ran McGill motorsport joints on his 800hp carbon focus and never broke or wore one out so thats where I did my shopping.
            Mine runs 14 joints per side so yes well aware of the cost of bloody rose joints LOL
            Looking great though mate, bet you can't wait to get it back on its wheels again
            • terrybullwon
              • Mar 2006
              • 8782
              Cheers James,
              Yeah itching is a understatement but i am pretty screwed with out the suspension going to Gatebil last weekend did not help much
              Thats good to know about the McGill bearings i need some more for a few other bits maybe i'll try them out.
              Chef
              • Rocco
                • Aug 2007
                • 6393
                • Country: Spain
                #127
                can i have a ticket for droll in your car in 10 days??
                • Jonnybravo
                  • Aug 2008
                  • 2051
                  I bet lol, it will be worth the wait ( thats what I keep telling myself anyway lol )
                  As for McGill, I know their cheap which puts people off but we have all seen the punishment that Focus got !
                  I bet Gatebil was awesome, probably not quite as muddy as the weekend I had ha ha, hope you had a great time.
                  • terrybullwon
                    • Mar 2006
                    • 8782
                    Well it rain so ****ing hard on sunday it washed the time attack out
                    Yeah the focus is more than testament and it was hardly a budget build, add me to facebook i have a few Gatebil pictures there
                    Chef
                    • terrybullwon
                      • Mar 2006
                      • 8782
                      Yeah sure its not alot to look at though
                      Chef
                      • nervas
                        • 357
                        #131
                        those are ftom ford rear.. they have different sudpension there, also another longer comes as "traction bar"..
                        Xtra Racing
                        • Jonnybravo
                          • Aug 2008
                          • 2051
                          They are actually custom front arms, not rears and I was only showing the spherical bearing setup as you mentioned.
                          • nervas
                            • 357
                            #133
                            but wheel side spherical bearing is in housing that is welded. And they have made double adjusters:
                            Xtra Racing
                            • Jonnybravo
                              • Aug 2008
                              • 2051
                              The double adjusters come from dewitts. The arms were indeed fabricated.
                              A friend of mine owns a 98 wrc Subaru so I'll stick my head under it and have a look next time I'm over to see what you mean
                              • quattro84
                                • Mar 2006
                                • 947
                                He means that the bearing at the hub is fixed, cannot be rotated. Because of the crappy design of the McPh strut braking forces are being transferred by an opposed torque compared to braking direction. This torque will make your rose joint twist. That's why they use the double adjustable ones at the subframe side. Being a couple these can cancel out twisting forces because they offer dual opposed reaction forces.
                                Because the 'arm' is shorter on the bottom side the reactional force is bigger as well.
                                I would recommend to use dustcovers for these expensive Aurora's (used on the Works Evo WRC as well) to extend longevity. Will try to find the source for you guys.
