as a general rule with brakes, big + cheap = heavy
With which callipers? the Tourag, TT or 996? I know I will need a braket to mount them with, will the RS2 or Bambridge one do the job with the larger disc?
345 disc will probably work with the tourag caliper, but you'll need custom carriers.
996 route is tried and tested and parts are "off the shelf" but calipers are getting more expensive all the time as the ebay pirates buy up all the stock and mark it up for profit, you used to be able to get a good pair for £250, now you're lucky to get a trashed set for £300. Way of the world i guess.
Are these the right part numbers for 996 brakes? 996.351.425.11 & 996.351.426.11
I want to run big discs as I have the room (18" wheels) So I guess with 996 calipers and the 345 disc then I would just have to find someone to make me some carriers!
Yes those numbers are right. I got my 323mm A8 disc for 65 quid the pair, is it worth all the extra cash you will have to pay to gain 22mm?
Probably not to be fair.
Im I right in thinking that if I stay at 323mm A8 discs rather that the S8 345mm ones I can use the RS2 carrier or the one everyone seems to get from bambridge?
You can make you own hard lines, I've just done it and connected them straight on to the original flexi lines
Im sure you can, I have never done that before though and not sure if I have all the tools required so maybe easier to get pre-made ones. We shall see.....got to get the money together first.
