Acq 10vt - oldschool turbo power
  • Takumi
    • Oct 2009
    • 120
    • Home: Lithuania Current: United States
    Yo,
    was reading forum here quite a lot, thought i will share my experiment/project too...still it's 'in progress'
    SPECS:
    -MC2 engine;
    -034 camshaft;
    -VEMS ecu;
    -HX35/kkk26 #6 turbo hibrid;
    -custom header;
    -3inch full intake/exhaust system;
    -and other bits.
    450hp/650NM
    When i bought it... 2.3E 10v quattro.
    Began with underneath/susspension
    Bought and assembled ecu...
    In winter studied head porting/assembling...
    Back to susspension...
    convesion 4x108 -> 5x112 ARP studs
    Put PowerFlex bushes...
    Rear brakes upgraded to 280mm (g60)
    Atm 01A gearbox...
    Repainted engine bay
    kkk24 vs HX35/kkk26
    Brembo 323mm front brake upgrade
    Upgraded fuel lines from summitracing
    Fuel rail with 880cc injectors finished
    Custome made ingnition
    Fully rebuild bottom end with stock parts...
    3B pp + clutchnet ceramic clutch disc
    On it's wheels
    Upgraded MBC to 7A
    Some bits
    Inconel material for header
    Not much room left
    Putting in ecu wiring...
    Some view appears
    Head coolant mod
    Battery relocation
    Wiring
    FMIC installation
    3inch SS piping - heavy
    First drive!
    LINK: http://www.youtube.com/watch?v=RWwlcA0t0RQ
    Finishing interior
    3inch SS custom made muffler
    Exhaust - wanted to make it as silent as possible...and managed - very nice sound!
    First 'boost' try - franky look
    Almost finished
    Custom coilovers made...
    Afer some boost test, my new Erling head bolts failed and got blowby to coolant system...
    Meanwhile made heatshield
    Bought ARP head studs to hold desired boost
    There was dyno day, so took it to check what it's all about! Had some issues with boost creep before
    dyno (used 30mm audi WG), so tried to port it to 34mm, but have a little overbored, so the valve
    didn't hold and got this 'broken exhaust' sound + my spool took from 3k rpm to 4k rpm now ... still
    there was no time and i dyno'd it. All mapping was done same day going to dyno, so it's far from fine
    Atm redline is 6,5k rpm ( not sure why dyno measured only till 6k ) - plans are 7k rpm.
    LINK: http://www.youtube.com/watch?v=M3RcY...layer_embedded
    Now have ported another one, but this time success! Got valve lift ~3mm more and it's bored to 34mm +
    ported inside. Havent tried it yet, but hope it'll fix my boost creep.
    that's it - 2y build story in few hours ... no will start updating constantly here.
    Any comments about stock MC bottom end limits? What i'm worried are rod studs - should have upgraded it to ARP ...
    thanks,
    T.
    BLOG: http://quattro10vt.wordpress.com/
  • K Simmonds
    • Dec 2007
    • 7627
    Nice project, I'd have thought uprated con rods along with ARP studs would be a good idea with the size of that turbo. I've got an MC2 engine sat waiting to go in a B2 90 quattro so I'll be interested to see how you get on with this.
    1990 B3 2.0 80 quattro.
    1992 C4 2.8 Avant quattro
    1994 MTM RS2.
    1998 B5 TDI quattro Sport.
    2000 B5 TQS.
    • djh
      • Jun 2011
      • 1622
      very nice work there
      • Takumi
        • Oct 2009
        • 120
        don't think rods are weak...just afraid of rod studs. If changing only them, is it needed to get rods to machine shop for checking roundness? Have read some threads, that when torqued, crank doesnt spin
        • Twenny Benson
          • Jan 2011
          • 278
          I think you'll bend the rods before those bolts let go, if that motor see's any significant knock those rods are dead! Anyway, cracking job on the build, well done.
          2000 B5 A4 Quattro Sport ~ 2.0 20V GT30R ~ Gone
          1993 S2 ABY Coupe ~ Gone
          1989 2.2E Coupe ~ Gone
          • donce
            • Aug 2005
            • 127
            • Country: Lithuania
            433 whp or chp?
            • driftin jo
              • Sep 2007
              • 2222
              MC rods are very strong , they are heavy and not suited to very high rpm but you can load them up with torque with boost well past what would bend ABY rods, as long as you don't try and over rev them they will not let go.
              • driftin jo
                • Sep 2007
                • 2222
                Couldn't be more wrong , I had an MC2 years ago knocking its head off with boost with a to4 and it
                just kept going. The MC rods are very strong, not like puny 20v rods at all.
                • Takumi
                  • Oct 2009
                  • 120
                  Originally posted by donce
                  433 whp or chp?
                  as what in video can be seen - HT say it's whp, still i think it's crank hp.
                  So 600NM+ for these rods should be ok then? As per my plan i would like to hit 2bar boost, to get hx35 working in it's full efficiency...
                  • Twenny Benson
                    • Jan 2011
                    • 278
                    Fair do's, I stand corrected. Still seem's like a risky manouver to me though considering what they cost these days.
                    • Bram
                      • Aug 2006
                      • 2582
                      Very nice project you have there. 10vt with some serious power must sound good.
                        If it ain't broke and all that. They are stronger rods and will take the 600 nm so why change
                        • Billman
                          • 4129
                          Very nice build! Looking forward for updates.
                          Go Holset or Go RS4
                          • quattro84
                            • Mar 2006
                            • 947
                            Nice project.
                            Those stretched headbolts show why going to high tensile strength bolts like ARP's is not an option but a must have when running higher boost.
                            • prj
                              • Mar 2010
                              • 6308
                              I routinely map 20vt to 600nm on stock rods. Never bent any of them yet.
                              I think you can easily go to over 700nm with the MC rods, just don't rev the engine too much and don't knock (which is hard since VEMS does not have good knock control, so keep your timing SAFE). I think 6500 revlimit will be good for this car, once you fix the slow spool issue.
                              K26 #6 will run out of steam anyway over 6300 rpm's, so just run more boost early on, and get a nice powerband from about 3700 to 6200, and you will have a very driveable car.
                              Good luck with your project.
                              P.S. I also think that it is 433 chp, HX35 does not usually do 400+ whp on pump gas with small housing.
