Acq 10vt - oldschool turbo power
  • _ShurikeN
    • Mar 2010
    • 733
    • Country: Russian Federation
    #76
    Originally posted by Takumi
    Used audi A6 shifter and linkage
    Hi, do You have linkage partnumbers?
    I have come across linkage which was told to be from Allroad 4B. It has nubmers 8D0 711 271P and 8D0 711 151M on the shafts. Will it fit?
    • Takumi
      • Oct 2009
      • 120
      • Home: Lithuania Current: United States
      #77
      Hey,
      sorry, dont have any part #, but those were from Audi A6 c5 FWD - they are all the same i think....still you have to modify it.
      BLOG: http://quattro10vt.wordpress.com/
      • _ShurikeN
        • Mar 2010
        • 733
        #78
        If I'm not mistaken, not every linkage fits, because there are weak engines with 01A-transmissions. That's just an opinion after some pictures googling.
        Yours linkage looks pretty similar to that:
        • _ShurikeN
          • Mar 2010
          • 733
          #79
          BTW, You have a very interesting rear silencer design with side-enter. Is is custom made? Seems to be very space-effective to me.
          • Takumi
            • Oct 2009
            • 120
            #80
            regarding linkage - 01E ueses the ones that 'almost' fit - 01A is a different story and doesnt fit.
            About rear silencer, yes - it's custom made from SS - because of it's big space and 90deg bends inside, works a treat
            Sure would be nice to see if it makes any power loss because of BP it makes ( if any).
            • Jaswan
              • Apr 2011
              • 768
              #81
              hi, great car, it looks very nice on the gloss black oz (oz ultraleggera i think) rims.
              can i just ask what discs you used with the brembo 18z calipers please?
              jason.
              • Takumi
                • Oct 2009
                • 120
                #82
                if you mean brake discs, then it's 345x30mm Audi S8 d2 FL model.
                • Jaswan
                  • Apr 2011
                  • 768
                  #83
                  thank you!
                  did you use s2 hubs for your 5x112 conversion?
                  i also have 4x108 and im looking at options on changing to 5x112 for cheaper brake disc options.
                  thanks again.
                  • Takumi
                    • Oct 2009
                    • 120
                    #84
                    S2 hubs were too expensive, so modified my stock ones. For more info and pics you can visit my blog - more info there
                    • Takumi
                      • Oct 2009
                      • 120
                      #85
                      Anyone had leaking rear diff input shaft seal? Tried googling and searching here with no success. Found only this: http://forums.quattroworld.com/s4s6/threads/20220.phtml
                      Still hoping, that our diffs are easier to replaced it... ?
                      • Kieron20V
                        • Mar 2008
                        • 1505
                        #86
                        If you Have some sort of puller to pull the flange off I'd say it was do able on the car. You'll need a new crush washer to re apply the correct preload to the bearings but other than that should be pretty straightforward. uploadfromtaptalk1411554310467.jpg
                        1994 URS4 Avant RS2+
                        • Kieron20V
                          • Mar 2008
                          • 1505
                          #87
                          [ATTACH]49341[/ATTACH]
                          • Takumi
                            • Oct 2009
                            • 120
                            #88
                            thanks Kieron! As i understand - after unbolting center nut, flange wont come out easy ( as it does on gearbox rear end) - it is pressed in a bearing?
                            • Takumi
                              • Oct 2009
                              • 120
                              #89
                              took a while to make this simple and fun 'mod'
                              P.S. not sure why i cannot add direct video via: [YOUTUBE /YOUTUBE]
                              Not of links work with it
                              • Takumi
                                • Oct 2009
                                • 120
                                #90
                                upgraded my rears
