Acq 10vt - oldschool turbo power
  • Takumi
    • Oct 2009
    • 120
    • Home: Lithuania Current: United States
    #106
    not sure if it's stock. Have put it long time, so can't answer that ( housing didnt had any AR numbers, just some random numbers. Traded it for HX35 kkk26 #6.
    BLOG: http://quattro10vt.wordpress.com/
    • inline560
      • Jan 2010
      • 25
      So it's a kkk hotside, paired to hx40x
      • Takumi
        • Oct 2009
        • 120
        #108
        no, this one is T3. Before had HX35 paired with KKK.
        • inline560
          • Jan 2010
          • 25
          Ahh I see, full boost be 3800?
          • Tille
            • Feb 2014
            • 41
            Hello,
            I have also installed the COP 10vt. After 10000tkm the upper part from the spark plug disengaged by the vibrations from the engine. I recommend a holder or something for the ignition coils.
            Best regards
            Audi Coupe Typ89 10V Turbo - VEMS - Billet K26 - Deka 630 - E85 - 3" Exhaust
            • Takumi
              • Oct 2009
              • 120
              #111
              Not dead - still fighting for more 'oldschool' turbo power
              • Thuppu
                • 4115
                What oldschool is that?
                • Biturbo
                  • Aug 2011
                  • 591
                  • Home: Lithuania Current: United Kingdom
                  #113
                  Nice turbo,I know that makes some power
                  • bn-01-wso
                    • May 2009
                    • 471
                    • Country: Romania
                    #114
                    How much power do you think the hx40 is able to make on a 10VT? I don't think i have enough funds to finish my 20vt so i am also planing on putting the hx40 on the 10v and hope it doesn't blow (stock rods).
                    • Takumi
                      • Oct 2009
                      • 120
                      #115
                      Hey!
                      Have little time, but still on track for more HP
                      Anyways after latest MODs i felt lack of gains, LOGs didn't show much of improvement and oddly i was getting DP gasket blown frequently. Ok - it was time to test exhaus BP.
                      And guess what, my 3inch exhaust with 1 muffler on boost is giving me 1bar of BP(total exhaust manifold BP boosting 2bar is 2,4bar)
                      Thinking that muffler is the culprit i removed it and still the same.
                      Question is - could this be because of WG that goes to DP and makes some kind of curtain for main stream flow? Because i removed exhaust totally(left DP and WG as seperate) and top end differance was like WOW(VE ego corr went like +12% above midrange to keep 0.8lambda and IAT dropped, EGT didn't any significant differance).
                      How should i make a proper exhaust? Is 3inch enough for hx40 boosting 2bar+? Still not sure about HP, but my 1100c are @92% DC with E85 so there should be some gasses escaping. Open WG is not an option, as i didn't like it before
                      How latest exhaust looks with WG inlet could be seen:
                      Any ideas welcome
                      Thanks!
                      • diesel des
                        • 3896
                        #116
                        Keep the wastgate separate and use a separate silencer for it. See my urq thread
                        • Takumi
                          • Oct 2009
                          • 120
                          #117
                          Ok, so the issue was...
                          Now i get 0,15bar peak
                          P.S. WG dump is now external.
                          • diesel des
                            • 3896
                            #118
                            And how does it drive with this restriction removed?
                            • quattro-nick
                              • Sep 2012
                              • 1746
                              • Country: Belgium
                              #119
                              great job
                              TWINCHARGED power,zero lag
                              AEM W/M injection
                              • Takumi
                                • Oct 2009
                                • 120
                                #120
                                soon will dyno it, but the difference in top end is day and night
