Acq 10vt - oldschool turbo power
  • #16
    thanks for comments!
    BLOG: http://quattro10vt.wordpress.com/
    • #17
      Hey, where did u buy the parts for the coilovers?
      • #18
        custom made by a local grinder (was cheaper than parts from ebay etc)
        • #19
          Brilliant! love a 10 valver
          • #20
            Nice work, nicely documented, looking forward to updates when posted.
            Enjoy the car, you've certainly earned it.
            Kind regards.
            • #21
              Wow! Loads of work gone on there & thanks for sharing all the pictures!
              • #22
                Well I never knew that the MC bottom end is that strong, was expecting to have to change the rods in mine, shalt bother now. Did you make the exhaust manifold yourself? If so would you be interested in making another and how much would it cost?
                Edit- Just relised that the EM you bulit would be no good to me as I'm using a B2 body
                This has got to be one of the most interesting projects on here.
                • #23
                  some 'on-road' action with friend's S2
                  http://www.youtube.com/watch?v=Qq4vZ...&feature=feedf
                  • #24
                    Brilliant project Takumi, I enjoyed reading about your progress in your blog. Well done.
                    • #25
                      Fair play that's a cool project - something different and the 10v sounds awesome!
                      Thanks for sharing
                      • #26
                        Some updates...put forged rods and bigger turbo to push it over 500hp mark - hope to test it till winter
                        • #27
                          HI there...did some testing and atm what i'm concerned - oil pressure drops on acceleration...noticed this with the old setup too...I'm using AAN oil pan ( alu), but the oil pick up has plastic thingy from simple NG motor...do you have any pic or know, if 20vt engines additional use some different plastic cover/anything for oil pickup? Do you get this problem too? I get oil press like 4bar, but even in 3rd when WOT, it drops to 2,5bar or so and slowly comes back to where it was...tried fillin oil above MAX, no changes
                          thanks!
                          • #28
                            Nice work you have done.
                            With regard to oil pressure. I recently bought an oil filter that resulted in my pressure dropping dramatically. Bought another brand of oil filter (the one I normally use) and it was back to normal.
                            Worth a try.
                            Secondly I did not see a oil cooler fitted. So if it's there and a I missed seeing it, OK, but otherwise best fit one.
                            Regards
                            Ryss
                            www.autostart.co.za
                            • #29
                              thanks for reply, but my problem is related with acceleration... idle/cruise oil press is topnotch...and yes, i have aftermarket oil cooler - temps are now well controled
                              • #30
                                strange, that i'm the only one with oil surge problems
