Stroker S2
  • Sydney mate, how about you?
    ABY S2 stroker (work in progress)
    B5 1.8T quattro
    B4 2.3 (decommissioned)
    • Bellingen, near Coffs Harbour on the mid north coast.
      • Originally posted by Pat D View Post
        This item was bought from 034 Motorsport some yrs ago. Pretty sure they should still have it available.
        ...... I don't see it ... https://store.034motorsport.com/cata...e+body+adapter
          plus 1 here for Sydney.
          Where abouts Pat?
          im Western Sydney near Wetherill Park
          Current:
          1993 Audi S2 Kingfisher Blue - GTX3582r w/ E85 = 430kw atw
          Past:
          2002 Audi S4 Nogaro Blue Stage 3+ - 250kw+ atw
          2001 Audi S3 Silver - 169kw+ atw
          • Originally posted by sailaz View Post
            Might be deleted, I did purchase it a very long time ago.
            B5 1.8T quattro
            • Originally posted by momento1 View Post
              Where abouts Pat?
              I'm up the mountains a little, my work is near you though.
              B5 1.8T quattro
              • All going as planned, shed should be up second week in March
                filedata/fetch?id=2015283&d=1518039499&type=thumb
                This gallery has 1 photos.
                B5 1.8T quattro
                • Feels good when you get that slab down.
                  • I find it interesting that we both have rather similar builds, and both were postponed by similar changes of priorities in life. In the next few years I'm looking at building a 20'x40' shop (at least) on our new farm. Limiting factor -- so far as I can tell right now -- will be the trusses and the concrete pad.
                    Will be following your build even closer now!
                    Find me on Instagram @pry4sno
                    2010 Golf Sportwagen TDI /// #farmenwagen
                    2002 Dodge Ram 2500 24v Cummins 4x4
                      Nice shed slab.
                      Im part owner in a family company in concrete construction and development.
                      I could have helped you with your slab....
                      Current:
                      Past:
                        Nice shed slab.
                        Bugge r, should've been on here more often. Slab turned out ok, wish I got rid of the top layer of soft dusty crap before the shed went up. PITA to do it with everything in there.
                        B5 1.8T quattro
                        • Still lots of things to do around the shed to manage stormwater, but almost done and slowly getting back into things.
                          B5 1.8T quattro
                          • Hi Pat - looks to be plenty of room in there, do you want to temporarily look after another one which is suffering from the recent rain we've had in Sydney ;-)
                            John
                            Sent from my Nokia 7.1 using Tapatalk
                            • Hello! I've just been browsing through your post and saw your plans to deal with some underseal / corrosion issues around the subframe mounts...
                              A very good idea indeed. I have had my subframe off to get it galvanised and found trouble lurking under the underseal
                              I peeled some off by hand and yep, it was wet underneath and yep, corrosion was there.
                              Check it all and sort it in one go or else you will be back. Don't ask how I know this
                              The worst bits where I have had to cut metal out are where the old exhaust heat shield was fixed. Notorious rain trap and many a coupe rots there quietly and unseen.
                              This gallery has 3 photos.
                              • Originally posted by OzS2 View Post
                                John
                                Does it run? Bring it!
                                B5 1.8T quattro
