Extreme RS2 SEDAN replica [CUSTOM PARTS SERVICE]
  • helvetesmaskinen
    • Feb 2012
    • 84
    Update
    was time for some blasting! Before...
    And after...
    The RS2 wishbones...
    1000HP RS2 SEDAN project!
    Follow this at 07K Motorsport
    -JONUS RACING-
    • quattro84
      • Mar 2006
      • 947
      Nice, what did you do with the wisbones? Zinc passivated?
      • helvetesmaskinen
        • Feb 2012
        • 84
        They're electrically goldzinc'ed
        Results from blastering:
        -JONUS RACING-
        • ralleyquattro
          • Oct 2007
          • 536
          • Home: Poland Current: Canada
          #34
          Looks great... nice shiny parts!!
          www.quattro.ca
          B2: 82 Urq into Sport quattro, 82 4000 2-door, 83 80q 2 Door, 83 Ur-q CDN, 85 Ur-q Euro with 3B, 86 4kq, 59,000km
          B3/B4: 91 CQ, 93 90q 2.5TDI, 94 80q avant 2.5tdi, 94 S2 Avant
          • helvetesmaskinen
            • Feb 2012
            • 84
            Thanks!
            The brown glue from the asphaltmats is leavng terrible marks after it was removed, so some groundingpaint did fine, but I will use some thin black textile to cover the floor later
            Scratched and coated here also. Done for 3 bosch 044 pumps & catchtank. Battery and catchtank will be fitted in the bowl. Low cg and weight in rear=perfect for quattro cars. The original tank will be mounted soon again. I just have to find out how it works with it's very special form and how it works to suck fuel from the different levels caused by it's form. Some vaccum **** etc...
            -JONUS RACING-
            • helvetesmaskinen
              • Feb 2012
              • 84
              Cleaned alot and the galvanized area will be coated:
              Now I need a s2/RS2 subframe in front...
              -JONUS RACING-
              • helvetesmaskinen
                • Feb 2012
                • 84
                Some better pics on the RS2 diff:
                The linkage to the S/RS4 transmission arrived
                -JONUS RACING-
                • helvetesmaskinen
                  • Feb 2012
                  • 84
                  Lightened and ready to fit some very light plasticwindows! Will also get some RS2 mirrors
                  -JONUS RACING-
                  • 1badquattro
                    • Mar 2011
                    • 53
                    looking good man, keep it up!
                    http://www.efiexpress.com
                    Like us on face book: http://www.facebook.com/SalkowskiMotorsports
                    • helvetesmaskinen
                      • Feb 2012
                      • 84
                      Thanks! Thinking of fitting an S2 coupé diff instead of the long sedan/avant S2/RS2 diff. It's shorter and some say it's a better choice for aggressive launches. Is it possible to fit on the sedan without customization? What is your 50 cents?
                      -JONUS RACING-
                      • speeding-g60
                        • Aug 2008
                        • 1186
                        the B3 has the same rear diff as the S2/CQ. i use it ALL STOCK for >800 AWHP launches and 1.400 60' and 9.3x 1/4 mile runs. locked of course. and i launch with ~16 psi boost as well :-)
                        • helvetesmaskinen
                          • Feb 2012
                          • 84
                          Time to work again! Big news is that I can proudly present my new partnership with Custom Parts Service! Real good shop with nice staff and some real good products!
                          -UPDATE-
                          ABY Front subframe has arrived and also the complete S2 limo rear.
                          The CP-S Alu bushings to the subframes is on it's way, new 82mm bearings, and soon the Nylatron bushings will come to the wishbones etc...! Will also use aluminum bushings to transmission and rear diff.
                          Also as said, I think it will be the KW v.3 coilovers!
                          -JONUS RACING-
                          • helvetesmaskinen
                            • Feb 2012
                            • 84
                            Finally the KW v.3 has come in to Sweden from Germany, so with all other stuff I ordered, I'll recieve it soon.
                            Lite bilder som inte kommit opp innan:
                            S2 ABY subframe powdercoated
                            All powdercoated
                            Mounted! Now I need the S2 ABY gearbox mounts for the DSY
                            New 15cm M12 and alu bushings. Will hold for my planned low 0-62. The special quattrotank. Amazing how it all fits... when looking at the tank at the pic below, and thinking of the big subframe and also thinking of the diff to be mounted, Audi did quite a good job with the B4 chassi.
                            Pressing bearings...
                            with an swedish 150 tons press...
                            I've ordered new ones. Enought camber can be set here.
                            As said, the rest is on it's way. Has taken some time to get what I want.
                            -JONUS RACING-
                            • helvetesmaskinen
                              • Feb 2012
                              • 84
                              Now before Friday, CP-S will send me the KW v.3 coil's and some other good ****!
                              -JONUS RACING-
                              • helvetesmaskinen
                                • Feb 2012
                                • 84
                                The KW v3 coils been late... but some new goods...
                                -JONUS RACING-
