2013 Time Attack S2 Avant build
  • #46
    Well had a nice delivery today. these arrived
    now it is time to start nodding the turret to fit.
    lance
    Boost is what makes the world go round.......!
    • #47
      Right.
      std strut brace bracket removed
      Std top mount cup removed and new one beside
      home made center tool made
      Now time to trim the turret.
      lance
      • #48
        Well a little time later and a bit more modding ect this is what it looks like so far.
        lance
        • #49
          Nice project, looks like you've been busy
          91 Modded 3B
          14 A6 Avant Black Edition
          • #50
            Well so far all has gone bloody well.
            Home made clamp has been made and flattened the turret. just got to weld up the holes and grind off.
            Here is a pic with it in place.
            lance
            • #51
              Coming together nicely
              Sold ABY-stock
              • #52
                Who is making the cage for you ?
                • #53
                  Good work Lance
                  what did you use to cut the turret out of interest? The steel is pretty thick and you've made a nice tidy job of it
                  • #54
                    Originally posted by Error404 View Post
                    Good work Lance
                    I used a air saw to cut out 95% of the metal. then a die grinder with a carbide bit to get the last of the metal out then a 20 mm belt sander to finish it off.
                    Should have it welded up tonight and finished off. then can start on the other side.
                    Lance
                    • #55
                      The cage is not for a s2. found a cage that is close and only needs a trim on the rear legs to make it fit.
                      lance
                      • #56
                        Well after having a good night down the workshop lastnight my boss has been a diamond and let me have the day off as my next job does not start till tomorrow.
                        so just finished off the turret.
                        • #57
                          Well been a good day.
                          all the turrets are done. just about to paint and stone chip.
                          lance
                          • #58
                            Nice work. Who is your boss and where can i get one like that?
                            • #59
                              Looks nice
                              Any idea of how much caster you'll be able to get?
                              Does it raise the ride height(is mounting point lower then std)?
                              • #60
                                Originally posted by Audi_CQ View Post
                                Looks nice
                                well off the top of my head i think i can gane (on top of std angle) a nuther 18 to 20 degrees if wanted.
                                will do a proper mesurment on sat when i am back up my workshop,
                                no the rideheight will stay the same, even tho the camber/castor plate is lower the coilover does not have the std audi top mount any more so give or take it stays the same
                                lance
