2013 Time Attack S2 Avant build
  • #61
    Originally posted by martinws View Post
    Nice work. Who is your boss and where can i get one like that?
    lol, trust me after a day you would wanna kill him, but after a night of sexy time he is a good boss,
    Boost is what makes the world go round.......!
    • #62
      well that was not as bad as i thort of a job,
      top mounts all finished,
      will get a castor/camber mesurment on sat when i am back up my workshop
      lance
      • #63
        As a good rule of thumbs, for ever 10mm you move the strut top or bottom, you add 1 degree, so looks like you've moved it about 20mm backwards and sideways, so 2 more degrees of camber and castor seems sensible. You may not want all that camber though.
        Have you fitted offset subframe mounts to move the subframe forwards? Could add another degree or so of castor and sit the wheel more centrally in the arch.
        • #64
          If you reverse right and left ball joints on the control arms, so they move to a more forward position, how much should you move the top mounts towards the back of the car so the wheel stays centered in the wheel arch? Has anybody thought about that? And what will be the castor then? If no one has tried, when I have time I will try to calculate it.
          • #65
            swapping the ball joints gives about an extra 6deg of castor but the wheels will foul the arches
            • #66
              Yep, I know, that's why I wrote to ask if someone knows how much the top mounts should be moved back so the wheels return to their original location
              ... how much should you move the top mounts towards the back of the car so the wheel stays centered in the wheel arch? ...
              • #67
                Well got bored today.
                trim is coming out. cage should be here next week.
                lance
                • #68
                  Measure the distance from wheel center up to top mount and divide with distance from wheel center down to lower ball joint. This ratio gives the ratio you have to move the top mount back.
                  • #69
                    lance
                    holy crap, thats gonna rattle! lol
                    • #70
                      Well been a good night up the workshop.
                      Got most of the sound deafening off the floor. Now time to clean it all off and start to get rid of a bit of loom.
                      lance
                      • #71
                        Well all i can say is i am high as a kite. knees and hands are killing me but all the glue is coming off.
                        also sold a big par of the trim so have some space aging.
                        Lance
                        • #72
                          Looking forward to updates on this, Nice work.
                          What solvent did you use to remove the glue?
                          Eric
                          95 S2 Avant under rebuild.
                          • #73
                            Lol the good old classic. a gallon of unleaded.
                            Lance
                            • #74
                              god mate, you did a hell of a lot in the short time since I was there! car is gonna be mega, cant wait to see this come together and thanks for the seats!
                              • #75
                                Made light work of that glue in there. Whats next after the cage goes in?
