Originally posted by martinws
View Post
2013 Time Attack S2 Avant build
As a good rule of thumbs, for ever 10mm you move the strut top or bottom, you add 1 degree, so looks like you've moved it about 20mm backwards and sideways, so 2 more degrees of camber and castor seems sensible. You may not want all that camber though.
Have you fitted offset subframe mounts to move the subframe forwards? Could add another degree or so of castor and sit the wheel more centrally in the arch.Cheers'en, AndyC
If you reverse right and left ball joints on the control arms, so they move to a more forward position, how much should you move the top mounts towards the back of the car so the wheel stays centered in the wheel arch? Has anybody thought about that? And what will be the castor then? If no one has tried, when I have time I will try to calculate it.
Originally posted by afterburner View PostYep, I know, that's why I wrote to ask if someone knows how much the top mounts should be moved back so the wheels return to their original location
