2013 Time Attack S2 Avant build
  • recall
    • Jun 2010
    • 336
    Well had a nice delivery today. these arrived
    now it is time to start nodding the turret to fit.
    lance
    Boost is what makes the world go round.......!
    • recall
      • Jun 2010
      • 336
      Right.
      std strut brace bracket removed
      Std top mount cup removed and new one beside
      home made center tool made
      Now time to trim the turret.
      lance
      • recall
        • Jun 2010
        • 336
        Well a little time later and a bit more modding ect this is what it looks like so far.
        lance
        • SteveH
          • 4460
          Nice project, looks like you've been busy
          91 Modded 3B
          14 A6 Avant Black Edition
          • recall
            • Jun 2010
            • 336
            Well so far all has gone bloody well.
            Home made clamp has been made and flattened the turret. just got to weld up the holes and grind off.
            Here is a pic with it in place.
            lance
            • andy10v
              • 5996
              Coming together nicely
              Sold ABY-stock
              • Jonnybravo
                • Aug 2008
                • 2051
                Who is making the cage for you ?
                  Good work Lance
                  what did you use to cut the turret out of interest? The steel is pretty thick and you've made a nice tidy job of it
                  • recall
                    • Jun 2010
                    • 336
                    Originally posted by Error404
                    Good work Lance
                    I used a air saw to cut out 95% of the metal. then a die grinder with a carbide bit to get the last of the metal out then a 20 mm belt sander to finish it off.
                    Should have it welded up tonight and finished off. then can start on the other side.
                    Lance
                    • recall
                      • Jun 2010
                      • 336
                      The cage is not for a s2. found a cage that is close and only needs a trim on the rear legs to make it fit.
                      lance
                      • recall
                        • Jun 2010
                        • 336
                        Well after having a good night down the workshop lastnight my boss has been a diamond and let me have the day off as my next job does not start till tomorrow.
                        so just finished off the turret.
                        • recall
                          • Jun 2010
                          • 336
                          Well been a good day.
                          all the turrets are done. just about to paint and stone chip.
                          lance
                          • martinws
                            • Oct 2008
                            • 917
                            Nice work. Who is your boss and where can i get one like that?
                            • Audi_CQ
                              • 940
                              • Country: Norway
                              #59
                              Looks nice
                              Any idea of how much caster you'll be able to get?
                              Does it raise the ride height(is mounting point lower then std)?
                              • recall
                                • Jun 2010
                                • 336
                                Originally posted by Audi_CQ
                                Looks nice
                                well off the top of my head i think i can gane (on top of std angle) a nuther 18 to 20 degrees if wanted.
                                will do a proper mesurment on sat when i am back up my workshop,
                                no the rideheight will stay the same, even tho the camber/castor plate is lower the coilover does not have the std audi top mount any more so give or take it stays the same
                                lance
