Drilled the holes for welding.
My Audi S2 coupè Version 2 - full restore - Red rocket from Norway
The girbox needed a wash.
I drained the oil, not a bad idea...
Are thise plugs for oil cooling?
I am going to wash i with a heated presurewasher, blast it and paint it black.
I got some work done. So here does the bad phone pictures come!
This is the rear seat support, where the previous owner cut a big hole for 2 cables
This hole was tricky to fix! Not alot of space to work with and alot of angels on the steel plates.
From the inside of the car.
Time for an update, with bad pictures and nearly no texy as always
Alot of parts is delivered for powder coating!
Cut out rusted plates, make new, weld, weld some holes, weld the hold together and grind! Im getting tired of this now... I want to assemble parts on the car!
I blasted this exhaust hanger with sand and sprayed on weld primer.
I cut of this rust pieces.
And made new.
Welded on.
From the other side.
I made this part and i am going to weld it on the inside in the luggage room between the vent and the taillight. The car got this on the other side, so i guess there was one on the other side aswell, when the car was new.Last edited by kinaputt; 8 December 2015, 18:43.
