From Audi 100 to urS4 in a week
    #376
    I'm kind of amazed that nobody on the forum has started making them... Must be someone out there with a 3D metal printer lol.
      #377
      This is what we need - http://www.sjmautotechnik.com/troubl...s/3256tool.jpg - That will work on AAN/ABY/ADU
      whilst the 2084 - http://imagehost.vendio.com/a/176130...175_VA6016.jpg - will work on 3B (and older Audi 5-cyls)
      • hunker7
        • Mar 2014
        • 3487
        #378
        I need to see if i can get it to my mates garage and use air gun to open it up.
        '93 Audi UrS4 Avant
        '15 Audi A7 quattro 3.0 TDI
          Errr, no find the right tool. People are wary of lending them out as they are hard to find and expensive.
          I have a 3B one I have modified to work on an ABY pulley.
          I'm not sure if it will work on the AAN as it uses a different snub mount bracket.
            #380
            See there is a 3256 on UK eBay right now - not cheap but not outrageous either - given the importance of its job !
            • irishs2
              • Apr 2009
              • 2455
              2" box
              Eric
              95 S2 Avant under rebuild.
              • hunker7
                • Mar 2014
                • 3487
                #382
                Would i be able to open it with air gun?
                '93 Audi UrS4 Avant
                  #383
                  Don't waste your time... you need the crank locked to torque it up as well - and you aint doing that with an air gun unless you want the entire forum to hunt you down and taunt you with ridicule about such monkey business ;-)
                  Buy the right tool - do the job right - then sell onto the next guy for same money.
                  • hunker7
                    • Mar 2014
                    • 3487
                    #384
                    ...or I could make one. What I don't understand how does it fix into the pulley?
                    '93 Audi UrS4 Avant
                    • hunker7
                      • Mar 2014
                      • 3487
                      #385
                      Originally posted by irishs2
                      This won't fit my AAN?
                      How does it lock into the pulley?
                      '93 Audi UrS4 Avant
                      • irishs2
                        • Apr 2009
                        • 2455
                        There is a lug inside the pully that fits the tool
                        Eric
                          #387
                          The pulley damper is shaped / slotted where the round end goes in... the other end prevents it moving by countering against the snub mount (in case of 2084 tool) or being bolted to block (in case of 3256 tool). I like the ingenuity of Andy10V's tool made from box section (and a pair of Val's old knickers) but it did the job.
                          • irishs2
                            • Apr 2009
                            • 2455
                            Or you can go creative
                            Eric
                            • hunker7
                              • Mar 2014
                              • 3487
                              #389
                              Brilliant, thanks a lot. I better start measuring that thing up. I am not spending £70 on a tool if I can make one
                              '93 Audi UrS4 Avant
                                #390
                                I have cut one off with an angle grinder before (shocking behaviour) on a busted AAH engine by taking off the damper first of all - works fine if renewing the crank pulley, washer and bolt (duhh) but you still need a locking mechanism for the rebuild. The V6 motor locks up entirely differently - much easier actually.
