My sleeper
    Worth it if only to get rid of the huge bump steer the OEM setup has
    • hammer
      • May 2008
      • 242
      • Country: Austria
      #317
      Originally posted by quattro-nick
      why this steering modification?
      to make more room for the downpipe?
      or to run less revs with the steering wheel because of the shorter arms on the struts?
      I dont like the orginal, it is not very stable and indirectly.
      I bend the right arm to get my big downpipe in, this wos not the best solution and the bump steer wos also not the best...
      Gesendet von meinem PLK-L01 mit Tapatalk
      • hammer
        • May 2008
        • 242
        • Country: Austria
        #318
        First Test Drive wos very good, love the Steering. With the bigger Housing it comes little later, so i have to adjust bit more Timing. But first i have to adjust the Axes and waiting for better Weather.
        • hammer
          • May 2008
          • 242
          • Country: Austria
          #319
          Some updates. I had to much castor ~12°, so i go little forward with the damper.
          also i have some heat problem and i ned a heat protection for the turbo
          Next problem i found out that my selfmade air cooler lost air, so i make a new with a cheap net. But it work fine.
          • hammer
            • May 2008
            • 242
            • Country: Austria
            #320
            And i changed the mounting from the stabilizer bar. Don't like the oem on the shock absorber, who is always turn left and right and change the preload from the stabilizer bar.
              How did you remove the damper insert from the KW tube before you welded new steering arms?
              I am considering adjusting mine to dial out bump steer.
              • hammer
                • May 2008
                • 242
                • Country: Austria
                #322
                There is a nut on top of the damper. It's easy to remove
                • hammer
                  • May 2008
                  • 242
                  • Country: Austria
                  #323
                  You can also change the height at the steering like this. For a better parallelism with the wishbone.
                    Thanks. I will have a look next time the dampers are off the car.
                    Yes I have done that too to try to correct the angles, but best to have shorter tie rods like your setup
                    • hammer
                      • May 2008
                      • 242
                      • Country: Austria
                      #325
                      Started to make a bigger Oil pan. Not the most beautiful but should Work fine😊.
                      Space for 7l Oil. So with the Filter and cooler it should be 8.5l
                      Time to get ready for the next Trackday 29-30 march at Panoniaring
                        #326
                        Would an oversized oil cooler with a thermostat not given you the desired increase in oil capacity without as much effort, albeit more cost ?
                        And also an oversized oil filter.
                        Just musing...........
                        Enjoying your work / thread - thanks.
                        • V6quattro
                          • Sep 2008
                          • 949
                          Would an oversized oil cooler with a thermostat not given you the desired increase in oil capacaity without as much effort, albeit more cost ?
                          The reason for a sump like this is to prevent oil starvation i think.
                            #328
                            Yeah, didn't think of that.
                            Thanks for reply.
                            • hammer
                              • May 2008
                              • 242
                              • Country: Austria
                              #329
                              Yes its as V6 quattro said, to prevent oil starvation.
                              • hammer
                                • May 2008
                                • 242
                                • Country: Austria
                                #330
                                http://cloud.tapatalk.com/s/593536c4...605-WA0002.mp4
                                http://cloud.tapatalk.com/s/5935370d...330-WA0019.mp4
                                Here two short videos from Panonia circuit.
                                Not the best driving, but i had big problems with my brakes[emoji21]
