Small Urs6 project!
  • #16
    C4 UrS FMIC install with a non-NAmerican Front Bumper
    This thread:
    http://www.audifans.net/modules.php?...234&highlight=
    • #17
      I don't have more pictures but the headlights are on and the bumper is on too, no problems with that. The intercooler mounting was temporary solution, just wanted to see how much I needed to cut the bumper. But it seems to hold pretty well.
      • #18
        Yours, showing that you cut sheet metal that doesn't have to be cut if the pipe is taken back more first before heading to the throttle body.
        The sheet metal was cut long time ago when there was water cooled intercooler.
        • #19
          Nice project
          Is that Holset Hx35 Super?
          • #20
            Originally posted by maiks View Post
            I don't have more pictures but the headlights are on and the bumper is on too, no problems with that. The intercooler mounting was temporary solution, just wanted to see how much I needed to cut the bumper. But it seems to hold pretty well. The sheet metal was cut long time ago when there was water cooled intercooler.
            Okay. I am surprised but if it works it works.
            • #21
              Yep, it is holset hx 35 super.
              Yes it works, but we'll see how it works. The headlight is about 1-2 cm from the pipe. I have stronger engine mounts, but maybe while accelerating, the headlight might pop out Luckily the headlights are almost always available
              • #22
                Little more pictures of intercooler and pipes. If someone thinks why the hell are pipes painted green - green was the only paint I had and I painted them because I don't like shiny pipes behind the pumper. If I have time then I'll make some more pictures.
                • #23
                  I had time to make pictures. Here U can see that the pipes are not shown, thanks to the green paint
                  • #24
                    väga hea auto ja projekt!! )) Palju jõudu juba on?
                    • #25
                      Kahjuks ei tea pole dünot teinud aga üks on kindel vähe veel!
                      • #26
                        What intercooler did you use?
                        And do you have a front picture from the bumper?
                        • #27
                          Intercooler is 630 300 75.
                          • #28
                            Finally the turbo blanket arrived, hood gets without that so hot that I can fry eggs there. I bought it from PTP turbo blankets and quality is pretty good. It was pretty expensive and there are lot of cheaper blankets available, but life has tought me that cheap isn't always good.
                            • #29
                              upgrade. I changed my coil hardness. Last owners made hardness does not look reliable
                              New ones! I bought those from user Norbitron. Top quality.
                              And the old ones
                              New ones left has 3 pin old 2.
                              • #30
                                I cant see the pictures?
