Small Urs6 project!
Okay. I am surprisedI don't have more pictures but the headlights are on and the bumper is on too, no problems with that. The intercooler mounting was temporary solution, just wanted to see how much I needed to cut the bumper. But it seems to hold pretty well.
The sheet metal was cut long time ago when there was water cooled intercooler.
but if it works it works.
Yep, it is holset hx 35 super.
Yes it works, but we'll see how it works. The headlight is about 1-2 cm from the pipe. I have stronger engine mounts, but maybe while accelerating, the headlight might pop out
Luckily the headlights are almost always available
Little more pictures of intercooler and pipes. If someone thinks why the hell are pipes painted green - green was the only paint I had and I painted them because I don't like shiny pipes behind the pumper. If I have time then I'll make some more pictures.
I had time to make pictures. Here U can see that the pipes are not shown, thanks to the green paint
Finally the turbo blanket arrived, hood gets without that so hot that I can fry eggs there. I bought it from PTP turbo blankets and quality is pretty good. It was pretty expensive and there are lot of cheaper blankets available, but life has tought me that cheap isn't always good.
upgrade. I changed my coil hardness. Last owners made hardness does not look reliable
New ones! I bought those from user Norbitron. Top quality.
And the old ones
New ones left has 3 pin old 2.
