Adding brakes.
360mm rotors need to resize to 352mm
I put an extra bolt to make changing the tires easier.
New bolts 1cm longer and adapters to avoid bolts from moving.
I am too lazy for making special adapters, so I just put bigger nuts over there. They must be 15mm or 14mm, don't remember.
Even the brake lines fit. But there I must figure something out, they vibrate and aluminium may break.
Because the rotors are now 352mm the brake pad's are like this:
A little hammerite. No rust needed.
Ready for test ride!!
Now, hard braking might throw the car on the roof!
