block heater - consists of the heater itself, a T shaped screw thing and a long nut (and washers n' seals of course).
The issue is, the T shaped screw needs to go into the hole first at and angle and then you have to somehow slide the heater onto the screw. and there's no channel up the inside of the heater so just trying to get it through the hole is difficult. The hardest thing though is it's impossible to hold the screw in place. I tried needle nose pliers and even a thin bent wire. But whatever you use to hold it in place then obstructs the heater from moving into place.
I was about ready to throw stuff around and call in an expert when I had an idea though... I'm pretty chuffed with this to be honest. I slid a bit of heat shrink slid over the screw. Quite tight but not tight enough that it would break off when I pulled it off.
so I managed to get the T screw in, thread the heat shrink through the hole in the heater, then hold the heat shrink while I worked the heater into the recess. As I pulled the heat shrink out I kept going so it came right off and left about 5mm of thread poking out. I managed to wedge a small flat-bladed screwdriver against the thread of the screw to hold it in place and then gently got the nut started. phew!
After that I just left it in place until I ran the cables through, and then tightened it up.
I've installed the mini-socket in the left ring of the audi badge in the grill. Not sure if I'll regret that and end up buying a new grill. But it's a PITA being really low down on my A4 so I thought "fukkit" and did it. Interior heater is approximately in place and I will find a proper place to mount it when I have the trim under the glove box put back in. There's not much space on that side because of the Air Con gubbins hiding behind the tiny glove box. So I ended up running the cable through a large grommet on the driver's side and then over behind the centre console. I still need to get some silicone in there tonight because the grommet was partially destroyed (it's a big, fat, armoured cable).
In other news the floor's bloody wet on the passenger's side under the carpet. This explains the mould when the car was sitting for a while before it was transported from Wales to Germany. I know the window on that side isn't sitting quite right so I'll need to get the door card off and left the frame up a bit to get it fitting better. Kit replaced the bonnet pull cable grommet previously so that's not the problem (other side of the car too) so I'll need to check the seal around the air/heater intake too. First thing will be to get a heater inside and maybe a pile of rice to absorb as much moisture as possible
Or because I was given the heater for free by a friend (saving me a lot of money) maybe the screw was shorter than it should have been for a7A. It came out of an AAN I think. But anyway, there was no way that T screw was going in while attached to the heater. It would have been easier to put my elbow into my ear
