Good work
My wannabe S6 Plus project
Big thanks to everyone who have responded. It gives encouragement to go on and improve.
Originally posted by macspring View PostAstounding.
As good as mdz's thread, and that's saying something.
Love everything you've done including the window trim changes.
The only things I would have done differently is 255/40/17 tyres, black brake calipers and Bilstein shocks with H&R 29800 springs with Albert's front arb mounts to increase castor.
While stating the above as things I'd pick out, there are many many more items that you've done that are brilliant and the end result is stunning given what you've had to do.
Thanks for sharing. Made my day, puts the work necessary on my UrS6 into perspective.
Enjoy.
I chose 225/45 because I was a little concerned of fuel consumption(I drive 20k km a year) and how the car would handle with 255 width tires and also I was using A6 struts when I was fitting the wheels so 225 was the widest I could fit at that time. 255/40 tires would look much better also I guess. I could use some opinions how the 255/40 wheels feel under C4. I am considering buying something wider as my next set of tires.
The colour of brake calipers I was considering black/gray/red/yellow and decided to go with something more eye catching.
Lower ride height would look better but I needed the car to stay comfort and practical since it is a daily driver so I decided to stick with factory sports suspension. I would love to see her sitting lower. I have been thinking of doing some coilovers so I can change the ride height since we get quite a lot snow in the winter.
My friend started playing snow plow with his quattro.
The quattro's like soft snow.
How did you remove the old black plastic sill trims and what did you use to put them back?
Thanks.
Nice car
Have you done any upgrades to the engine yet?
Otherwise trying to get it running as good as possible.
The best tuning here would be AAN.
Cleaning the injection pump head.
All the debris that has come with years.
ATTENTION! If you are allergic to DIESEL do not scroll down. I guess these should be censored in this S forum but you have been warned.
Cleaning the diesel injector nozzles. A bad nozzle.
A good one.
Some good bits and pieces.
Hochspannung
I see your point re the size of the tyres given the annual mileage, but more so snow in the winter season.
And the same good reasons for sticking with the oem sports suspension - mileage and the snow.
The colour of the brake calipers, we'll just have to agree to disagree.
Kind regards.
Thanks guys!
Originally posted by RichLV View PostOnce you finish being student, put a proper engine in there.
Keep on going bro, not that many C4's left out there.
Originally posted by Joop View PostWas it enough only to clean the injector nozzles?
I also added some weight to make the car more quiet and comfortable.
And i covered it with this wavy and soft insulator where there was room. I think the best result gave me the doors. Hardly any studded tire noise coming in after fitting them. Big difference.
That NOISY Cd-box.
S6 strutbar still to be fitted.
I also retrofitted the "+" battery terminal since my car came without it because of the missing AC system I guess. So I changed the whole battery wiring to starter with original one that has the "+" terminal. (Yep I'm crazy )
I have Bosio PP520's in mine, it goes quite well, smokes a bit under heavy acceleration, but still get good MPG. I also need to fix the prop shaft as it vibrates under heavy acceleration.sigpic
