Since the stock MAF is getting more expensive all the time (270 EUR at the time of writing), I thought perhaps it could be a good idea to make a MAF conversion kit for standard cars.
The kit would consist of:
1x Bolt-in Hot-Film MAF, which will fit directly instead of the stock item without modifications to intake.
2x ECU Chips
1x Connector and fittings
1x Instructions
The fitting would mean that the connector would have to be changed.
The chips would be standard good Stage 1 software for a stock car. 1.4 bar boost with good timing.
The price I am aiming for is ideally about the price of the MAF at the dealer. So around 300-350 EUR.
If the hot-film MAF ever breaks, then it would be possible to replace it for around 100EUR at the dealer with an exchange part.
The hot-film MAF is more reliable, it is possible to clean it with Q-tip and alcohol and it also gives less flow restriction.
Now, I am not sure if there would be much interest in this, but I thought I'd throw this up here.
The kit would be ABY/AAN (possibly ADU) only. The 3B ecu is too slow to deal with the hot-film MAF.
2x ECU Chips
1x Instructions
