3.5" silicone couplers will fit on it.
It's around 92mm from memory.
If needed Pro-M can provide pretty much any configuration MAF though.
Also, I can map Motronic to pretty much any MAF as well, as long as it gives a 0-5V signal and reads high enough, no difference really.
The reason I used the RS4 MAF is because it is easily available, fairly cheap and reads up to 600hp (standard, without meth etc).
