Stock ECU MAF replacement project
BMW 740iA e38 - ProjectComment
China rods, stock pistons, 7A cams, built head, completely maxed 630cc injectors at 4 bar, relayed 044 pump.
HX40 Super is a bit too much, at least if you want to drive it on your street, just like this GT35R. At least in my opinion...
I'd say a HX35 or a GT30R is all that is needed.Comment
The combination of cams and headwork shows nice result beyond 6000rpm... and the GT35 is clearly up for the flow requirements !!!
Any idea on compression ratio here for reference ?Paul Nugent
Hmm, HX35 is a ~500 crank hp turbo, my CT should be that also, hopefully. Garretts are too expencive for me.
going by the rule of thumb and repo's previous indications, injectors on a 5cyl are roughly making the amount of power in hp crank as their cc @ 3bar,
in other words, maxed out 630cc should give around 630crank.
to me GT35 is a bit optimistic for 700hp
nonetheless, the idea here is to prove that RS4 maf is more than enough for at least more than 600hp, so the ultimate problem with the RS2 motronic mapping is now gone!
Good news Dmitri and well done, as this was a huge problem for those being on the limit of RS2 Maf of around 500ish hp. Now they can get a map done properly at least if they dont look to map themselves and get into it.Comment
If you look at picture you can see it's race octane. Jason's dyno is brutal - put that car onto any other dyno, and you will see higher numbers.
500?Good news Dmitri and well done, as this was a huge problem for those being on the limit of RS2 Maf of around 500ish hp. Now they can get a map done properly at least if they dont look to map themselves and get into it.
MAF is maxed out on a 3071 car from 4000 rpm to redline.
Stock MAF can't even read 400hp.Comment
prj is there anything for the 3b maf that can be done that dosent cost the earth or have to buy oneComment
In theory yes, in practice you will just have to buy a new maf.Comment
Seems that I need to change the turbo to a HX40 super. Any info about the specs, turbo, cams, head, injectors etc..?
Dyno sheet looks good!
